64 olds 98 interior lite removal
Old Jan 2, 2016 | 02:05 AM
aussie oldsmobile 98's Avatar
hi guys
I'm tryin to removal the back pillar interior lite in my 64 98 sedan , so wot is the correct way to taken em out ??? I have trid to turn em , look in factory workshop manual with no luck..not in there???..don't want to brake things ideas????
thanks mate
gino
Old Jan 4, 2016 | 11:31 AM
D. Yaros's Avatar
If you are referring to the bulb, I would suspect the normal procedure to be:
1-Push In
2-Turn/Twist Bulb
Old Jan 4, 2016 | 12:23 PM
rocketraider's Avatar
Oldsdruid
Use a small thin bladed flat screwdriver to carefully pry the lens out, then push the bulb in and twist to remove as Dave has suggested.
If you break the lenses (round lamps on sailpanels) the lenses are reproduced in both styles- concentric ribbed and flat. If it has larger rectangular lenses not sure if any reproductions are available.
Old Jan 4, 2016 | 05:40 PM
hey thanks heeps guys , I wasn't sure being tryin to turn the outer casing..lol///
FirstClass 383
Aug 6, 2013 06:17 PM
Goldhawg
Sep 5, 2012 03:19 AM
wmlewis
Feb 27, 2012 08:26 PM
80_cutlass
Dec 29, 2010 05:50 PM
442Harv
Brakes/Hydraulic Systems
Apr 3, 2008 12:34 PM
