Windshield washer pump
Old Sep 29, 2017 | 03:01 PM
gkhashem's Avatar
I had someone replace the pump 3 months ago with a kit on my wiper motor and it was working for a while.
Noticed some windshield fluid on the garage floor today so I took off the reservoir and cleaned it and determined tank was ok, but the fluid was leaking near the hose nipple.
So I trimmed the hose and it still got moist so I replaced the whole hose. No leak now. But now the pump has seemed to fail again.
This was annoying since I thought I had fixed it. I can hear it pumping but only had a small minute steam from one nozzle at first. Now nothing.
I took the hoses off the outlets on the pump and am getting nothing.
So I think the pump went again. Am I correct?
Old Sep 29, 2017 | 03:42 PM
CRUZN 66's Avatar
Olds Fever
Did you check the actual function (suction) of the pump??? Remove the hose from the tank to the pump, and then cycle the pump... Using your finger, or a piece of paper, can you feel the pump sucking... If you can, there is a blockage in the hose, if not the pump is bad...
Rocketbrian
Mar 31, 2018 05:08 PM
joesw31
Jan 16, 2017 08:01 AM
pcard
Tech Editor's Desk
Nov 4, 2012 06:27 AM
DeltaDevil88
May 27, 2011 08:41 AM
bjtstarfire
Jan 24, 2008 10:42 AM
