Headliner screws
Old Dec 16, 2022 | 09:35 AM
gkhashem's Avatar
Headliner screws
On my 1977 Olds 98 Regency Coupe , the seller recovered the headliner but did not do the finishing touches which I fixed.
One finish was putting the clothes hooks back up. I had to pull down the headliner on one side to reattached the dome light wire and when I did I could see the roof had a double metal wall where the clothes hook screws went into.
After playing with it awhile to no avail to line up the screw hole with the hooks. I got smart and noticed the screws were self tapping and the metal it went into was a double wall on each side. So I drilled new holes and easy as pie screwed in my hooks.
The last item that is a bit loose is the block in the front that holds in the sun visors. I really cannot find the screw hole. Is there a double wall there? Anyone know, I suspect there may be but do not want to drill a hole in my roof.
I have come to the conclusion on assembly, they must have drilled holes and screwed these items in. It would have been slow to actually find a pre-drilled hole with the headliner in place. No way they could have perfectly aligned the headliner with a pre-drilled hole. Thus the reason for a double wall to add strength and to aid assembly.
Old Dec 29, 2022 | 02:27 PM
gkhashem's Avatar
Guess no one knows?
Old Dec 30, 2022 | 03:59 AM
Did you drop the headliner enough to see where the sun visor block mounts? You can always use a straight pin and probe the headliner near the sun visor block for the screw holes.
Old Mar 26, 2023 | 06:09 PM
gkhashem's Avatar
I can try that, I did this for the clothes hanger hooks and determined the headliner had been moved just enough so the screws did not align with holes anymore,
olds70supreme
Feb 23, 2020 06:02 PM
James71Cutlass
Sep 3, 2019 09:57 AM
Kevin W
Aug 24, 2019 05:57 PM
44blue
Aug 22, 2016 03:28 PM
richeyb
Aug 2, 2011 06:40 PM
