Good quality direct fit radiator suggestions for 77-84 98?
Old Apr 22, 2024 | 06:44 PM
illumined's Avatar
1978 Ninety Eight
I noticed when I pulled it out that the original radiator had sprung a leak at some point. I've done some searching, there are certainly aftermarket options available from places like Summit and Champion that say they will fit, but I've also read a lot of very negative reviews about bad quality. I've searched the forum here and found a number of glowing reviews for US Radiator and Cold Case. Unfortunately US Radiator's 98 offerings only go up to '76, clearly meant for the previous generation and Cold Case only seems to offer them for A bodies. Can either of these be made to work? I've also seen it suggested to have the original rebuilt, I just don't know which shops are good. I've had a lot of experience with bad shops of other kinds so unless they have a good reputation that isn't really a bulletproof solution either.
Old Apr 22, 2024 | 08:57 PM
rocketraider's Avatar
Oldsdruid
I was able to get a direct fit replacement for the 78 Custom Cruiser thru Auto Zone several years ago, which should be the same as your car. Granted, it was aluminum core with plastic tanks, and generic to all GM B and C body cars but it fit and worked well.
Old Apr 23, 2024 | 05:03 AM
I recommend NOT shopping at your local auto parts store. I have a cheapy from O'Reilly Auto Parts in my 71 98 and it's on my list to eventually replace. It's a generic aluminum and plastic radiator that is designed for multiple applications. No doubt it's sized just big enough to keep the 455 from overheating. There's even a secondary exhaust port below the radiator cap that's blocked with a rubber nipple and hose clamp.
Old Apr 23, 2024 | 08:20 AM
illumined's Avatar
1978 Ninety Eight
Yeah exactly, so what good options are there for a '78?
Old Apr 29, 2024 | 11:44 AM
Mikeyt's Avatar
Mikeyt
I just ordered an aluminum replacement for my 62 from Ebay, Focus Cooling.
Ebay guarantees it to fit. I'm pretty sure it won't without modification to the saddles but all other dimensions are exact match.
For the price if it works a few years it's a deal.
This will give me time to have my original recored once I get the funds.
I'm skeptical of the quality but we will see.
Old Apr 30, 2024 | 02:06 PM
illumined's Avatar
1978 Ninety Eight
Yeah that's one thing I'm trying to avoid, for mission critical parts like this I'd prefer a one and done as much as possible.
Speaking of which I do actually have an update, on a whim I decided email US Radiator to just to see.....and it turns out they do have radiators that seem to be the right size. I was directed to part number 008318ANN, and they have a few options that don't have the heater hose connector. This is a promising lead and I'm still following through for the specific version that's the right fit, but so far so good. I think there's a path forward with them.
Old Apr 30, 2024 | 02:11 PM
Mikeyt's Avatar
Mikeyt
US Radiator seems to have a ton of radiators for not so common cars.
I'd bet they can square you up.
Old May 1, 2024 | 05:55 AM
Mikeyt's Avatar
Mikeyt
I just found another place called Radiator Express that does OE style replacements.
They have the one for my 62 98 for a little less the US Radiator.
Just another option.
Old May 26, 2024 | 09:33 PM
illumined's Avatar
1978 Ninety Eight
US Radiator does indeed have the right sized ones, for the 98 it's the Modine 530. When placing the order by phone I discovered they could make it to be exactly like what I have, complete with a spot for a low coolant sensor and also not having a heater connection. They're still working on the order but so far so good. I also emailed pics to their sales people to make sure it's what I need. I opted for the high efficiency upgrade, figured extra cooling with a 403 won't hurt so it will perform even better than the one I have now.
Old May 27, 2024 | 04:08 AM
Here's a link.
https://usradiator.com/
I'm surprised they have copper and brass radiators available. Did you order a copper and brass or aluminum radiator?
Old May 27, 2024 | 10:21 AM
illumined's Avatar
1978 Ninety Eight
Here's a link.
The model number indicated it's a copper & brass. My impression from looking at their other options is that whatever they have is most likely just a replica of whatever the original would have been. It wasn't cheap by any means, but it seemed like my best bet for a long lasting solution.
SirVelociraptor
May 27, 2024 07:37 AM
76 Regency
Aug 15, 2019 07:20 AM
SanTan Devil
May 7, 2019 11:27 AM
The Flash
Ninety-Eight
Aug 6, 2017 09:01 AM
elwood565
Apr 3, 2010 11:49 PM
