Factory air cleaner with Holley carb
Old May 21, 2014 | 11:56 AM
1Fastolds's Avatar
On my 64/98, my engine currently has a different air cleaner on it, since it has a Holley 4 barrel on it. Is there a way to use the factory air cleaner, possibly with a different base, so that I can have the factory look with that stupid Holley underneath it?
Adam
Old May 21, 2014 | 12:03 PM
twintracks's Avatar
I would think yes. I have a '66 Toronado with a Holley, and the factory air cleaner assy is still in place. And, the problem with Toros and modifications is hood clearance.
Old May 22, 2014 | 06:06 AM
rocketraider's Avatar
Oldsdruid
Get a 1966 or 67 4-barrel aircleaner base. Those years had Q-Jets which should be same diameter as the Holley air horn and use the same airfilter element and upper housing as 61-64.
You used to be able to buy adapter rings to adapt different carbs to different bases but haven't seen those in years.
Old May 22, 2014 | 06:10 AM
X2 or you can modify the base of your stock a/c to accommodate the bigger opening.
Old May 22, 2014 | 10:13 AM
Arrowstorm's Avatar
Olds Wagonmaster
... I simply used a reciprocating saw to cut the base of my air cleaner when I moved from stock 2bbl to a 4bbl edelbrock. Then, sanded the cut and hammered the opening to form a smooth beveled edge. Of course, you need to be at least decent at metalworking and have the tools to do the work.
But I'm not gonna lie. The factory a/c with some kind of Olds decal or metal ring sure as heck beats an aftermarket a/c housing any day of the week. I wouldn't even consider anything other than a factor a/c.
Old May 22, 2014 | 11:00 AM
hookem horns's Avatar
Did you modify the snorkel also? 4bbl one is larger diameter.
Old May 22, 2014 | 11:17 AM
droptopron's Avatar
delete
Is it a single feed, dual feed or double pumper?
Dual feed or double pumper I'd think would be more difficult.
Old May 22, 2014 | 12:07 PM
1Fastolds's Avatar
How hard would it be to acquire a 4 barrel a/cleaner lower piece? I'm not even ok with metal work.
Old May 22, 2014 | 12:22 PM
Arrowstorm's Avatar
Olds Wagonmaster
Adam, are you looking for a "correct" air cleaner housing? I just looked up a few different air cleaner housings for 4bbl carbs that weren't very expensive on ebay. You might need to get a little creative with your search parameters though.
I didn't modify the snorkel because the one on my 4bbl Rochester in the other wagon wasn't much difference in diameter, nor were the others with a 4bbl base that I saw and though about purchasing myself before I decided to modify the base of mine.
Old May 22, 2014 | 04:58 PM
jag1886's Avatar
You can do it easily, I just used a 14 drop base Elcheapo MR Gasket air cleaner base and put my stock top on it. Works perfect and you end up with a stealth open element air cleaner.
Old May 29, 2014 | 06:44 AM
66ninetyeightls's Avatar
Land Yacht Captain
X2 that's exactly how I did mine as well!
Old Jun 8, 2014 | 04:04 AM
1Fastolds's Avatar
I just wanted to let you guys know that I used the suggestions here and bought a universal 14" air cleaner and used the base to install the factory air cleaner onto my 64.
Thanks- I 'll work on pics to show!
Adam
1965cutlassragtop
Jul 15, 2012 06:26 PM
j_link
Dec 27, 2011 10:34 AM
69CutlassAlex
Dec 2, 2011 08:01 AM
1964F85
Mar 4, 2010 05:42 PM
