65 98 dual exhaust
Old Jan 10, 2014 | 01:18 PM
m371961's Avatar
65 98 dual exhaust
My parts list so far.
S-manifold, Amazon!- $149. + ship
Fel-Pro flange gasket #60241, OR, Victor#F7187
Pipe Flange- AP#8778, Walker#31857, Arvin#578463,Maremont#F25 OR, Midas#X1140
Stainless manifold studs, McMaster-Carr
Old Jan 10, 2014 | 03:57 PM
bigoldscruiser's Avatar
2 '66 98's
What's the story?? Are you buying, selling, looking for these parts?? EXPLAIN!
Old Jan 10, 2014 | 04:05 PM
m371961's Avatar
If I was selling or looking for them I would have put them in the right forums.
Put them here with part numbers for someone else that may be looking to do this.
Old Jan 11, 2014 | 03:01 PM
2 '66 98's
Thanks! Now I understand. It may help someone else that may be looking to add dual exhausts. What did you do about the trans shift rod that is in the way? Original dual exhaust cars had one with an arch in it. You can also modify your existing straight one.
Old Jan 11, 2014 | 04:14 PM
m371961's Avatar
I am getting to that next, and will reply how the pre-made exhaust system I bought on e-bay works out. So far it looks as if the downpipe goes under the straight shift rod. The e-brake cable looks like it will rub the pipe, but I have to lay out the whole system to get it all aligned. The pipe kit is like a puzzle and I have not figured out how it all fits together. None of the pipes are labled which side. I am also working on the right side crossover block off.
Was very surprised to find the s-manifold at Amazon. The flange was a little harder to find. The gasket is common to the 231 Buick V-6.
Old Feb 15, 2014 | 07:39 AM
68 D88's Avatar
I did the same thing you are doing on a '68 Delta 88 about 10 years ago using the jeg's brand 2-1/2" kit for A-bodies (Cutlass/Chevelle). It worked out really good. I welded my system together and clamped at the mufflers. I enlarged the exit holes on the S manifold and the stock passenger manifold to received bigger donut gaskets and the accompanying flanges for the 2.5 pipe.
And that's a deal on the S. I paid $200 plus back then for mine.
Old Feb 19, 2014 | 06:22 AM
66ninetyeightls's Avatar
Land Yacht Captain
On my 66 I just installed the S manifold and had a custom dual exhaust installed at an exhaust shop. Why make it complicated?
Old Feb 19, 2014 | 08:25 AM
68 D88's Avatar
For me, 1) it wasn't too difficult, 2) was very affordable, 3) mandral bent, and I wanted to see if I could do it.
Old Mar 22, 2014 | 12:14 PM
m371961's Avatar
Finally got back to getting it done.
I agree that if you have a shop close by you that you trust a custom system is better then exhaust in a box. The system I bought was from Classic Exhaust. I would not reccomend them. I had to tweek the pipes to get it done.I also had a dissagreement with them over the length of the tailpipes, and even sent them a pic. They were about a foot short of the rear crossmember. They said the res. delete pipes were shorter. I didn't want to fight them and figure on putting custom ends anyway.
If you get one of these exhaust systems in a box, call and pay the extra ship to get the pipes full length.
Oh, if you use the starter brace bolt it to the block before bolting up the S-manifold.
All told, the cost including manifold and shipping,exh.system, clamps and universal hangers ran about 600$. I don't know how that compares to paying for a custom bend system.
Old Mar 22, 2014 | 01:19 PM
Oldsmaniac's Avatar
I know no shop that can reproduce the offset tailpipes on these cars so with all the factory hangers the pipes exit where they are supposed to. So how does the engine run now? Do you feel the xtra HP?
Old Mar 22, 2014 | 03:52 PM
Land Yacht Captain
My shop did it from manifold back for $480+ tax that includes capping the passenger side manifold. That's all mandrel bent. Looks and works perfectly.
Experienced exhaust shops should be able to replicate anything made by the factory.
Old Mar 22, 2014 | 04:28 PM
m371961's Avatar
Cap't, I would have happily paid that plus the cost of the manifold if I had someone close and the car was on the road. This was mandrel bent 2.25 pipe, at least before I tweeked on it
Oldsmaniac, it ain't on the road but I heard that 425 breathe a sigh of relief, not unlike when you eat a couple of bean buritos and have to excuse yourself from the room.
Terrible to have all those cubes bottled up like that. Sounds good with stock mufflers and no resonator.
Old Mar 22, 2014 | 05:57 PM
Land Yacht Captain
All that matters is that you are happy with it and it's one more step closer to cruising you around town!
Old Mar 22, 2014 | 07:11 PM
Oldsmaniac's Avatar
Well thats what I thought too and this is where Classic Exhaust fell on their face. I sent them an original 66 B body (88 to be exact) resonator with the short offset tailpipe attached. They tried 3 times and gave up to reproduce that tight offset bend. The 98 has the same bend but the assembly is longer due to the longer wheelbase. I still used Classic Exhaust but sometimes they dont get things quite right and yes it was a surprixe when I got my 442 exhaust and the long head pipes were cut in half... wtf.
Old Mar 23, 2014 | 03:30 PM
keepitolds's Avatar
dauls
I had my install a year ago at great muffler shop for 300.00 with h-pipe. She get up and go.
Old Mar 26, 2014 | 12:00 AM
cfair's Avatar
If you have a column shift, you'll need the half moon shifter rod to route over the drivers tail pipe. Shouldn't be too bad to fab...
Old Aug 13, 2014 | 06:36 AM
The Flash's Avatar
Hi
are there any that you can use that go straight down like the drivers side one?
for the passenger one?
i really don't want to cap it.
i have my motor out so i can see what it will hit
my cross over pipe was rusted out as well as the rest of the exhaust
i was thinking about getting that ebay kit but now ill just see if i can find a shop to do it
thanks
Old Aug 13, 2014 | 07:22 AM
Why not? Even if there were a manifold that would work, the flow difference between that one and yours with a cap would not be measurable. If you need a cap, they are reproduced.
Old Aug 13, 2014 | 07:44 AM
Oldsmaniac's Avatar
Hi
thanks
If you have the S manifold for the driver's side you can use a 66-70 Toronado passenger side manifold without the port to cap. The outlet position is close to original but not dead on so a muffler shop may need to form this down pipe.
Old Aug 13, 2014 | 07:48 AM
Oldsmaniac's Avatar
I know the SB manifold cap is repopped but am not aware of a repro cap for the BB manifold which has a larger flange/bolt spacing than the SB ones for the crossover port.
Old Aug 13, 2014 | 09:36 AM
Octania's Avatar
I actually have a jig or fixture I made to facilitate the making of the curved equalizer [shifter linkage] bar. sets the ends and curved part right so you can weld it up.
Old Aug 13, 2014 | 11:55 AM
m371961's Avatar
I ended up using a u-bolt to modify the shift linkage, used a freeze plug inside and outside on the crossover pipe stub for the plug.
Old Aug 20, 2014 | 12:50 PM
Land Yacht Captain
FYI
I am currently parting out my 66. It has an S Manifold and 1 year only complete custom dual exhaust.
All available for purchase! LOL
Old Oct 30, 2014 | 04:59 PM
billwaldo's Avatar
I can't seem to find that manifold on amazon.any clue?
Old Oct 31, 2014 | 04:54 AM
The Flash's Avatar
i just got mine yesterday from here http://www.themotorcompany.com/home.php?cat=112
they show out of stock now, contact them and see if they have any more
it looks good taking it to get powder coated today
also i decided to use the stock pass side one going to sand blast it and to see if i can find a 2 1/8 freeze plug to cap it ill shoot some pics when done
Old Oct 31, 2014 | 05:08 AM
Land Yacht Captain
They do make caps specifically to cap off the passenger side manifold.
Old Oct 31, 2014 | 05:24 AM
The Flash's Avatar
i heard they make one but not sure on the size
if i can jam a freez plug in there to me it would look cleaner but its hard to see in mine since its an a/c car
Old Oct 31, 2014 | 05:26 AM
The Flash's Avatar
can someone post a pic of the modified shifter linkage?
i have a tig welder but i just want to see whats its supposed to look like before i mod it
thanks
Old Oct 31, 2014 | 08:28 AM
Land Yacht Captain
it was an OEM part used by the factory so it would look "correct"!
http://www.ebay.com/itm/1964-77-Olds...&soutkn=R7ivJ9
Old Oct 31, 2014 | 08:43 AM
The factory blockoff plate was stamped steel, not cast. The correct repro looks like this:
Old Nov 19, 2014 | 04:16 AM
  #31
The Flash's Avatar
here is what i have after the coating
Old Jan 7, 2015 | 05:44 AM
  #32
m371961's Avatar
Anybody lookind for manifold? http://www.ebay.com/itm/151541282589...S:3160&vxp=mtr
Old Jan 7, 2015 | 06:13 AM
  #33
The Flash's Avatar
im still trying to figure out what i am going to do for exhaust
Old Jan 9, 2015 | 12:44 PM
  #34
StarGeneral's Avatar
Also going the same route on my Delta 88. I am currently bidding on that manifold that m371961 posted
I would surely appreciate a picture of the modified linkage, I had no idea I would have to modify my column shift linkage to fit this manifold till now.
Old Jun 3, 2015 | 07:09 AM
  #35
The Flash's Avatar
need some help
what kind of car do i need to find to get this shift linkage part that works for the duel exhaust? 66 olds 98
can some one please post a picture of a stock and modified one?
thanks
Old Jun 3, 2015 | 08:54 AM
  #36
Oldsmaniac's Avatar
Here is a picture
Old Jun 3, 2015 | 09:39 AM
  #37
The Flash's Avatar
thanks
what kind of car would i need to get this from?
Old Jun 3, 2015 | 09:48 AM
  #38
Octania's Avatar
I have a fixture I built in order to make those U equalizers out of a std one or two. Not much demand, so it sits unused. It holds the ends in place and the U while you weld the pieces solid. You have to get some A-body equalizers to donate the parts.
Old Jun 3, 2015 | 10:38 AM
  #39
Oldsmaniac's Avatar
thanks
They would only be used on full size Olds factory dual exhaust cars fom 1965 to 1970. They are hard to find and it would be better to have one made. You do not really need this by the way. An exhaust shop can make a pipe to fit that will not require the special linkage.
65OldsDelta88SuperRocket
Oct 27, 2011 09:16 PM
dynamic88builder
Jan 24, 2006 10:52 AM
copper128
Mar 21, 2004 09:43 PM
