64/98 glovebox lock cylinder
Old April 16th, 2015, 06:11 AM
Jandk's Avatar
Can this be changed, if I can find another case/housing to fit my own lockcylinder in to??
I believe the release mecanisme that pushes the hook, that grabs on the a metal thing inside the glovebox, is worn out, as the dosnt seems to let go enough to open, unless I help it a little on its way wi both hands, which only works every now and then.
Jandk is offline
Old April 16th, 2015, 12:02 PM
Ozzie's Avatar
Sometime lubricant helps the release mechanism, and on some cars the "metal thing inside the glovebox" can be adjusted.
Ozzie is offline
Old April 17th, 2015, 12:20 AM
Jandk's Avatar
Sadly that isnt enough, because when pushing the button, the "rod" or what ever it is called, that pushes the springloaded hook, must have lost some material caused by wear, as the hook is not being moved enough to release from the metal thing inside the glovebox.
The mecanisme it self work smooth as it should. Its just the moving distance that is the problem, and why I would like to replace it, without changing the lockcylinder.
I will take a picture during the day
Jandk is offline
'69CutlassVert'
May 31st, 2014 03:52 PM
507OLDS
May 5th, 2011 04:10 AM
dyscookn
June 11th, 2010 05:42 AM
mauls
June 3rd, 2010 07:40 PM
fallsguy
January 13th, 2007 05:48 PM
Quick Reply: 64/98 glovebox lock cylinder
