1983 98 Interior questions
Old Feb 19, 2020 | 05:57 PM
The Stickman's Avatar
Ok I just bought a rare 1983 Oldsmobile hearse based off a 98. Now with Hearse coach builders they tend to alter the interior somewhat. Sometimes it's just the rear. But sometimes there are some small difference. So could anyone tell me if this interior is stock.
Old Feb 20, 2020 | 05:10 AM
Stickman, the interior looks stock to me. The only things that don't look OE are:
1) The double DIN stereo in the passenger's side of the dash.
2) Overhead 6"x9" speakers installed with the aftermarket stereo. Are there speaker grilles on top of the dash too?
3) No headliner.
4) Aftermarket cup holder/console on the floorboard.
5) Aftermarket floor mats.
You can get OE fabric from SMS Auto Fabrics if you want to redo the headliner correctly.
Old Feb 20, 2020 | 07:42 AM
Ancient Iron's Avatar
What's "factory" in your car is original (seat upholstery, door panels, carpet and other trim) The radio and speakers are bogus.
I'm sure the headliner material just fell from old age and the panel was removed.
How is the rest of the car??? Post some pic's
Old Feb 20, 2020 | 04:39 PM
The Speakers may have been part of when it was at a haunted attraction. They also put them in the exterior of the roof. Not sure what the original headliner would look like just because of the raised hearse roof. The headliners are typically raised as well. Thank you for your help guys. I am trying to put her back the way she was.
Old Feb 20, 2020 | 05:31 PM
Yellowstatue's Avatar
It looks stock to me also, and be aware that there were light monitors available as well as volt and oil gauges on the left side of the steering column. My '83 looks the same inside as yours but my clock was within the radio. A blank plate or emblem where the clock hole is.
Old Feb 21, 2020 | 05:10 AM
Oh yeah!
Old Feb 23, 2020 | 12:38 PM
RumblinOlds's Avatar
That "digital quartz clock" came as standard equipment on the 1983 98 Regency
My 1983 Olds 98 original window sticker
Old Feb 23, 2020 | 04:20 PM
My '81 & '83 both have their clocks in the radio, and if I remember correctly the '80 & '84 did also. The '80 also had the CB option. They must have had up scale radios.
Old Feb 23, 2020 | 06:53 PM
You're right, the regular radios and tape players don't have a digital display, just a slide bar am fm tuner so they would all have that sperate clock. If you upgraded and got 1 like
this stereo like what came in the Riviera's you didn't get the dash clock. My 84 Riv came with an expensive Bose stereo with Bose speakers and each speaker had a little built-in amplifier, don't know if Oldsmobile offered that sound system?
Old Feb 23, 2020 | 07:52 PM
Thanks for the info guys. that clock info helps a lot.
Old Feb 23, 2020 | 08:31 PM
​​​​​​I like that old hearse. It'll make 1 hell of a station wagon, no pun intended. If you want to compare your hearse to some regular 98's go to gatewayclassiccars.com and search "Oldsmobile" scroll down to the early 1980's and there are a couple of very nice 1's for $10 to $15 grand with lots of pictures.
Old Feb 24, 2020 | 05:40 PM
Rick 98's Avatar
I have an 84 Regency with the AM/FM/CB and that digital clock was then standard......
rocwal
Ninety-Eight
25
Apr 2, 2020 05:59 PM
echilds
Sep 16, 2019 05:57 PM
FASTCUTLASS
Oct 8, 2017 03:58 PM
Nickyloves442s
Nov 3, 2015 11:36 AM
Rick 98
Oct 19, 2013 01:45 PM
