1972 98 fuzzies or sweeps?!?!
Old Oct 11, 2025 | 06:44 PM
Nelsons98's Avatar
Hello. Longs story short been searching for window felts for my 2 door hard top for ever. Sent universals with no luck. Had mine pulled and compared to others and found the 1972 88 convertible has the same front outer fuzzies. Purchased those and fit perfect. That kit came with rear quarter outer bottom seal which look to fit. Now I need rear quarter rear outside and all inside. They have plastic table that screw to the body. Which vehicles cross or run the same seals. Beating my head against the wall at this point. Have pics of all seals aswell.
Old Oct 12, 2025 | 04:43 AM
Hope you can find them. I was able to get exterior window sweeps for my 71 98 4 door hardtop.
Check here.
https://www.rubbertherightway.com/
Old Oct 12, 2025 | 08:00 AM
Nelsons98's Avatar
Yeah it’s been quite the task. The delta 88 door fuzzies worked perfect. And those were for a convertible. The quarters came as lower outer set which may work but I need the full set since they’re one piece on the car now and it would be 2 piece with convertible. Cutlass look similar as well. It’s just a lot of $$ to guess on seals.
Old Oct 12, 2025 | 08:01 AM
Nelsons98's Avatar
Rubber the right way I’ve used for a lot of vehicles. I talked to Clayton there and gave him measurements and pictures. The ones we thought would work unfortunately did not once I received them though.
AJFink
Jun 19, 2018 07:50 AM
Cymbals
May 22, 2015 05:09 PM
jrmarin
Jun 3, 2014 04:26 AM
JR442
Nov 29, 2012 06:58 PM
etohboy
Jun 16, 2009 06:37 AM
