1968 olds / Oldsmobile 98 brake drum swap problems
Old Sep 10, 2021 | 09:20 PM
Fresh98's Avatar
I am having a problem. Will the drums from a 1967 olds 98 fit my 1968 olds 98? Issue is that I had someone replace my wheel cylinders on my convertible 68 98 and the drums got cracked so I found a (magical and almost impossible) scrap yard that had 3 98’s online but they sent me hubs and drums from a 67 (hopefully on accident). I had these shipped across the US but hoping that they would fit before I waste my time trying to make it work. I just want to cruise. Olds is clean and original Jade green convertible with green leather.
Old Sep 10, 2021 | 09:46 PM
rocketraider's Avatar
Oldsdruid
65-70 Ninety Eight rear drums are the same with four wheel drum brakes.
If your car has front disc brakes all 59-70 big cars use the same rear drums.
Parts book shows different part #s between left and right sides.
Front drum/hub assembly is the same 1965-1969 big cars and work on either side.
Old Sep 11, 2021 | 05:10 AM
I have to admit, I've never been able to figure out why.
Old Sep 11, 2021 | 07:02 AM
Oldsdruid
Different pn on fronts thru 1963 made sense because of the LH lug nut threads. Rears, I don't understand either.
OP, you should be fine with the 67 drum and hub.
Old Sep 11, 2021 | 07:05 AM
Yeah, my point was why on the 64-up cars.
Old Sep 11, 2021 | 03:29 PM
Fresh98's Avatar
Thank you for the response. I did give the junkyard a call this morning and they told me that in their interchange parts book it says the drums from an olds 98 from 67-69 will work on my car.
Old Oct 2, 2021 | 06:17 AM
Eman79's Avatar
Good morning I have a 70 olds 98 and wanted to know if those drums worked on your car
Old Oct 2, 2021 | 06:18 AM
Eman79's Avatar
Good morning do you have the part #s on the rear drums I have a 70 olds 98
Old Oct 2, 2021 | 07:32 AM
Fresh98's Avatar
yes they worked
Old Oct 2, 2021 | 12:14 PM
Oldsdruid
From Nov 73 factory parts book:
Group 5.809
Part # 398466 RH, 398467 LH, rear drums, 1959-70 except F85, Jetstar 88, Toronado or police.
There are different part numbers for 68-69 Ninety Eight with disc brakes which used special 15" wheels. 398468/398469.
Hope it helps. Joe P says the Kanter drums work ok, just don't look like the belled and finned originals.
Old Jan 4, 2022 | 03:06 PM
Dking76's Avatar
Brake drum
Whats the name & phone number of the scrap yard that you called please? I’m searching for rear brake drums for my 1967 Oldsmobile 98.
Old Jan 5, 2022 | 05:57 AM
Fresh98's Avatar
Desert valley auto. Good luck.
Old Jun 29, 2022 | 08:02 PM
Fresh98's Avatar
yes they worked.
willypsilon
Aug 23, 2022 04:56 AM
Shortfuze
Feb 18, 2020 11:58 AM
dprestia
Oct 31, 2017 11:53 AM
orange442
Jan 3, 2012 10:22 AM
phil7395
Jan 1, 2012 06:19 AM
