1964 - 98 door moulding removal
Old Dec 31, 2018 | 12:53 AM
Jandk's Avatar
Happy new year everyone.
Can any of you guide me to how I remove the lower door moulding on the doors ?
Ofcause I removed the screws in the end, after that I gently tried to pry and massage the moulding off, but I am affraid to bend the moulding.
In general I could use a guide to how I remove stainless trim etc. since I have some small rust spots I need to adress here and there. Can any one help?
Thank you
Old Dec 31, 2018 | 10:33 AM
Jandk, I owned a 64 98. As I recall the molding on the bottom of the doors and fenders are pot metal. Be careful prying on it, it may snap.
Old Dec 31, 2018 | 03:57 PM
classicmuscle442's Avatar
The middle trim clips push into holes in door, there are some plastic pry tools that can be used to remove the trim. Could pull the door panel and take a look inside door and may be able to collapse clip and pop the trim off be starting on one end.
Old Jan 1, 2019 | 03:37 AM
Jandk's Avatar
I do have the door panel removed, but again I was a bit affraid to try alot of wrong methods, now my experience with trim and moulding on older cars are very little.
I will give it a go.. thanks
deaddds
Mar 11, 2019 01:33 PM
jdiggitydogg
Paint
Apr 21, 2014 09:13 AM
wal74
Mar 11, 2014 03:18 PM
1983oldsmobiledelta
Sep 29, 2010 11:36 AM
ctrain22
Body work
Jan 22, 2010 06:26 PM
