1949 98 Lug Nut Torque
Old March 5th, 2013, 06:24 PM
starfire's Avatar
Anybody know what it is? 80 ft/lbs, 100 ft/lbs, ????
starfire is offline
Old March 5th, 2013, 06:32 PM
Just good and hard.
I sincerely doubt that anybody in 1949 even thought about torque values on lug nuts.
MDchanic is offline
Old March 5th, 2013, 06:39 PM
starfire's Avatar
I suspect you might be correct, but thought someone might have info. I just don't want to over tighten them. Interestingly, the right hand wheels have "righty-tighty" lug nuts, but the left hand wheels have "lefty-tighty" lug nuts. The theory was that the spinning motion of the wheels would not let them loosen.
starfire is offline
Old March 5th, 2013, 06:54 PM
Tedd Thompson's Avatar
Ya and if you get them to tight you can't get them off with your little Lug wrench. When at home I put them on with my impact wrench then check with the lug wrench to make sure I don't have the above problem....Tedd
Tedd Thompson is offline
Old March 16th, 2013, 09:34 AM
starfire's Avatar
Hey, I found the torque specs in the '49 CSM I got. 65 to 70 ft/lbs. Just in case anyone cares.
starfire is offline
w-30dreamin
October 14th, 2014 08:51 PM
cuttyroe
April 18th, 2011 07:14 PM
69CuTlass S
September 18th, 2010 02:38 PM
fjross
September 13th, 2010 07:34 AM
yeahbuddy
Wheels and Tires
August 26th, 2010 09:38 PM
Quick Reply: 1949 98 Lug Nut Torque
