1949 98 Access Door
Old March 5th, 2013, 06:49 PM
starfire's Avatar
1949 98 Access Doors
I've seen two '49 98's this week, both are missing the door that should cover this area. At least it looks like there should be a door. Anyone have any idea if there is actually supposed to be a cover there?
Then there's this area here:
It's got a door with two bolts (yellow arrows point to bolt holes), but if you look you can see it is spot welded on the bottom (red arrows point to spot welds) so that it can't be opened. Anyone know if this should be spot welded? I'm going to replace the wiring to the headlights, but I'm not sure I can get there without removing that door. The spot welds have me confused.
starfire is offline
Old March 29th, 2013, 10:09 PM
JackWolfram's Avatar
Access doors
There is an access door on the right side of the upper baffle. It's purpose is to provide access to the radiator drain petcock. There is no access door on the left side of the upper baffle. The headlamp wiring harnesses are serviced by removal of the complete upper baffle.
JackWolfram is offline
SkylinesSuck
July 28th, 2011 04:34 PM
erudek
August 28th, 2009 05:45 AM
1971 sienna conv
Site Help
May 18th, 2009 03:04 PM
edgewoodrx
Site Help
April 25th, 2009 05:19 PM
bucknailer
September 26th, 2006 04:36 PM
Quick Reply: 1949 98 Access Door
