please help - looking at car now
Old Apr 9, 2014 | 02:18 PM
Cutlass Memories's Avatar
The last 6 digits on the cowl tag are supposed to match the vin, correct?
Old Apr 9, 2014 | 02:27 PM
RocketDevo's Avatar
Thats numbers on the cowl tag are just a Fisher body number, they do not relate to the VIN at all. Hope this helps.
Old Apr 9, 2014 | 06:35 PM
Thank you for the quick reply, you helped a lot. I researched all the casting numbers and transmissions, did not see this before on here.
Old Apr 9, 2014 | 07:22 PM
4speed455's Avatar
If you said the year and model car I'm sure some guys could tell you what the body plate should be. Numbers matching usually refers to the VIN and the part of the vin that is stamped on the engine and transmission showing they all came from the factory together.
Old Apr 9, 2014 | 08:01 PM
You are right, I just wanted to be sure something wasn't screwy with the VIN vs tag. It is a 70 442. I verified the 396021F block casting, and exhaust manifolds. Heads were 'J' and intake manifold was wrong number, so took more off price. It pays to verify things and not take someone's word for it. Can I buy the proper 'E' heads? If so, can someone tell me where?
aquabird
Oct 2, 2013 10:34 PM
Fakser
Apr 10, 2012 08:46 PM
oldsdroptop
Jun 2, 2009 07:03 PM
drtdobber
Feb 14, 2007 01:16 PM
monizrage
Aurora
Aug 13, 2006 01:24 PM
