Hello from north
Old Feb 24, 2013 | 06:07 AM
Oldsragger's Avatar
Hello from north
Hello, found this forum so maybe my b-body will fit inside here some where my project tread is in the eighty eight...
im 28yr old guy from Norway.
Old Feb 24, 2013 | 08:53 AM
fourtwenty's Avatar
Welcome and yes pics are a must. Lots of info here for you cheerio
orrick
Old Feb 24, 2013 | 12:50 PM
Oldsragger's Avatar
thanks, i will enjoy it
Old Feb 24, 2013 | 01:09 PM
Rocket331's Avatar
Velkommen, venn! (Did I say that correctly?)
Old Feb 25, 2013 | 11:32 AM
Oldsragger's Avatar
That`s right, hehe, thanks = takk
Old Feb 25, 2013 | 11:45 AM
Welcome aboard!
Very interesting custom dash you installed. Were the floor pans replaced or just in really good shape? They look great!
So, what are your plans for the car?
Old Feb 25, 2013 | 12:20 PM
Oldsragger's Avatar
The floor was in ok shape, but i welded some new steel plates and formed them a little, the driverside floor was the worst place,but it was ok to install new plate, all plate custom and formed by hand and hammer, the custom dash was made from before
i don`t have any orginal part`s and steering wheel now from this car,so it`s a little boring, but i like the dash to, but i will fix it a little better,maybe cut out new wood and oil it in ,it`s a little crack some places, want to and painting the dash with speedo, water temp up again, cause it not so nice now.
Other plans, well,, i will install some sterio at last, but first weld the chassie finish, and sandblow more under the car, and then paint it outside at the end. i will use this car when the snow go away, and in the summer, it is funny to drive.
Old Feb 25, 2013 | 02:08 PM
You know that the wood panels you installed on both sides of the dash cover the ventilation ducts and idiot cluster?
Old Feb 25, 2013 | 08:19 PM
OLD SKL 69's Avatar
GM Enthusiast
Welcome to CO! Glad to have you here.
Old Feb 26, 2013 | 03:22 AM
Oldsragger's Avatar
Forgot that part,i dont know who have install this wood panel before ,but i can try to check under the dash if i see the ventilation ducts, i should try to find me some orginal parts and install maybe.. but i have good heat in up to the window and to the floor anyway
what is a "idiot cluster" btw?
this maybe? anyway, i have a red light that is connected to the oil pump, and the foot brake, i have blue light for the long frontlight, and green turn lights, i will install a oil pressure gauge too
thanks OLD SKL 69
Oldbear
May 26, 2013 09:12 AM
xrunner66
Apr 10, 2013 04:56 AM
330oldsmobile
Dec 28, 2010 10:35 AM
lovelavc
Mar 20, 2009 07:07 PM
Lady72nRob71
Jun 9, 2008 02:16 PM
