Lifter issue: '68 Olds 442 engine (400)
Old Jun 6, 2012 | 06:50 PM
cjd's Avatar
cjd
I'm rebuilding the engine. One of the lifter ports is bigger than the others. I've heard that Oldsmobilie would sometimes bore out a lifter port to save the block. The lifters that were in the engine were thrown away. I need a part number for the oversized lifter. Thanks!
Old Jun 10, 2012 | 05:26 AM
Oldsguy's Avatar
Past Administrator
Welcome to CO, I do not have the lifter number but if you post your question in another forum besides this one you will probably get an answer. There are certain people that frequent certain forums all the time so you chance of getting a good answer would increase by doing that.
Old Jun 10, 2012 | 05:41 AM
joesw31's Avatar
The block should be stamped the lifter size where it was installed. Example;.010, .020 Etc.
I am not aware of over sized lifters being sold on the after market. Also, if it isnot samped, then, you need to measure them.
1yesfan
Aug 4, 2015 06:40 PM
Dead Reckon
Jul 14, 2014 02:35 PM
Finn5033
Jun 14, 2013 09:51 AM
rsandhoff
Jan 27, 2010 05:58 PM
Flye
Jun 3, 2009 03:48 AM
