Convertible Top Mounting
Old Aug 19, 2011 | 04:52 PM
dougm's Avatar
Can anyone tell me how the top cylinder piston mounts to the top frame. There is a bolt, nut, two folding washers and two bushings. The bushings go into the top cylinder piston and the bolt and nut holds it to the frame. Do the folding washers go between the bolt and frame or the frame and bushings?
Hopefully the pic is attached.
Old Aug 19, 2011 | 04:57 PM
69442C's Avatar
The washers go between the bushings/side of rod end and the frame. The nut should be a locking nut (if not get locking nuts) and don't go crazy when you tighten it up. There will be a little play and that is fine so don't squeeze the frame tight to the washers/rod end.
Old Aug 19, 2011 | 08:02 PM
dougm's Avatar
Thanks for the help
Old Aug 21, 2011 | 06:37 AM
Oldsguy's Avatar
Past Administrator
Welcome to CO.
GoBigRed
Brakes/Hydraulic Systems
15
Oct 5, 2015 01:00 PM
dougm
Aug 15, 2011 05:05 AM
shaks 442 clone
May 21, 2007 04:38 PM
muddy
Jun 10, 2006 04:24 AM
