top mounting plate on a 1970 cutlass
where can i get a top mounting plate for a 1970 cutlass mine was stolen out of my car along with the radiator a few weeks back
now i have my 4 row radiator, my new chrome water outlet, a high flow mr gasket thermostat, coolant enough for 4 gallons, and the upper and lower radiator hoses, and hose clamps.
hower i need this mounting plate or else im not sure if the radiator will stay in place and i dont wanna rig anything unless i really have too
i would like to buy a new one but i good shape used one would work also
thanks for the info in advance shak
the blue thing is what i am in need of got the pic out of a year one catalog to bad they dont sell it.........
Don't ask me how I know this...
A top plate from any 69-72 Cutlass will work. 68 will work also but the fan shroud is a little different and I'm not sure that the plate is identical. Unfortunately there are two flavors of top plate, the one for the 2 and 3 row radiators and the much more rare one for the 4 row radiator. Four row top plates show up on Ebay but are not cheap. In a pinch you can make a 3 row plate work by removing the rubber insulators that hold the radiator and flatening the forward leg of the "U" shaped bracket that fits over the radiator end tank. Reinstall the insulator to the now L-shaped bracket and it will at least hold your radiator in place (if not win any beauty contests). If you're really ambitious, get a second top plate and section the U brackets, welding the two pieces together to make a wider one that fits the four row radiator.
does this look like it will work? the guy says its for a 70 through 73 cutlass 442 would it work for my 70 cutlass
heres a pic, it looks bad but im desperate i cant find anything else i hit all the junk yards in my area even a specialty gm junkyard and nothing
also he said it should work with a 4 row radiator but he didnt seem sure seeing as he said "i think"
The width of the U brackets is different on 4 row radiators vs. the 2 and 3 row radiators. If it didn't come off a 4 row, it won't work on one. See my post above.
the three row and four row brackets are destinctly different when set side by side.. That pic does look like a 4 core support, BUT not for a 70-72 car.
BTW I found the ebay auction that the pic is on...the pic of the one flipped over verifies that it is a 4 core. I just cant be sure this is for a 70-72 Cutlass though... something is not right about it...
HOWEVER if it is be prepared for the bidding to jump quite a bit on this one. Anyone that know EXACTLY what it will fit will up the price.
John
John
John
John
i got my car running last night i rigged the radiator up in place with a bungie cord i had to bend the bottom brackets to accomidate the 4 row now i just need that top plate
i just dont wanna pay 200 dollars for this damn support last week i saw one on there going for 212 and it had days left on the auction but i guess i have to bite the bulletor i could just wait on it and have my buddy make me one out of aluminum i just need to get him the dimensions
If you can do some fabricating I can provide two of the three core top plates and you could do the cut/weld as Joe suggested to get a wider saddle to fit over the top of the four core. I'm up in Medford Oregon so the shipping shouldn't be bad. $20 plus the ride for two 3 core top plates if you decide you want to try it. John
BeenThere
Nov 18, 2017 11:58 AM
tcarroll
Jul 28, 2014 12:16 PM
Toms cutlass
Feb 25, 2013 08:12 PM
