72 olds 455
I need some help on this. just bought the 455 olds motor it has been somewhat taken apart down to a short block. I need to know if the g heads are worth puting the money into? I don't know what the cc are and if i can use them and flat top pistons to get around 9.5 to 1 in comp. this will be my first olds motor build so i will need some pointers on the in and outs of building an olds. the engine is going in a 67 vista cruise with an auto tranny would like to build as much horsepower in it as possible and kept a stock converter. i'm looking at a comp cam but don't know which one would be the best fit. will punch in out 30 also.
Thank you in advance Charlie
G heads are from the 1971 model year. They have hardened valve seats and about 80 cc chambers (as to all big block Olds heads). They are a good starting point. The factory high compression pistons had about a 6 cc dish. Today's 0.040" compressed thickness head gaskets will drop compression about half a point or so from advertised CR for a given set of pistons. The advertised CR usually assumes a thin sheet metal head gasket.
sx455raidercelticfan
Nov 23, 2010 05:45 AM
SKINNY IL
May 14, 2010 07:12 AM
