72 olds 455
Old Jun 24, 2011 | 07:30 PM
2000anderson's Avatar
Question 72 olds 455
I need some help on this. just bought the 455 olds motor it has been somewhat taken apart down to a short block. I need to know if the g heads are worth puting the money into? I don't know what the cc are and if i can use them and flat top pistons to get around 9.5 to 1 in comp. this will be my first olds motor build so i will need some pointers on the in and outs of building an olds. the engine is going in a 67 vista cruise with an auto tranny would like to build as much horsepower in it as possible and kept a stock converter. i'm looking at a comp cam but don't know which one would be the best fit. will punch in out 30 also.
Thank you in advance Charlie
Old Jun 24, 2011 | 09:07 PM
72 cutlass455's Avatar
Yes the g heads are cool you will need to use dish pistons as flat tops would increase the compression a lot.
Old Jun 26, 2011 | 10:00 AM
G heads are from the 1971 model year. They have hardened valve seats and about 80 cc chambers (as to all big block Olds heads). They are a good starting point. The factory high compression pistons had about a 6 cc dish. Today's 0.040" compressed thickness head gaskets will drop compression about half a point or so from advertised CR for a given set of pistons. The advertised CR usually assumes a thin sheet metal head gasket.
Old Jun 26, 2011 | 10:08 AM
vette442's Avatar
Look closer - they should be GA heads. There will be a smaller capital "A" to the right of the G. If they are just G, then you have 1971 heads.
Terry
Old Jun 27, 2011 | 11:26 AM
Smile thanks
Thank you all for the info. Is their some place i can get a stroker kit for this motor?
Old Jun 27, 2011 | 11:38 AM
dc2x4drvr's Avatar
www.btrperformance.com/
Old Jun 28, 2011 | 08:49 AM
Oldsguy's Avatar
Past Administrator
Welcome to CO, I see you already got some good help from our members here, great!
Old Jun 30, 2011 | 08:01 AM
Correction on head type
I took a closer look at the heads they are not g heads they are GA heads
so are they as good as the g heads or do I need go go to after market heads?
Thank you
Old Jun 30, 2011 | 09:44 AM
The Ga are good heads that used the large valves no need to go after market.
Old Jun 30, 2011 | 11:11 AM
Thank you 72cutlass455 that will save some cost that can be put to good use else were in this restore.
dp442
Feb 15, 2011 04:22 PM
sx455raidercelticfan
Nov 23, 2010 05:45 AM
SKINNY IL
May 14, 2010 07:12 AM
egknz
Jul 21, 2009 01:09 PM
