Get a Load of This New Guy
Old Nov 10, 2025 | 10:31 AM
ZSmith74's Avatar
Good Morning, all.
I’m Zach from Montana.
Last year, I lucked out and got my hands on a 1971 Cutlass "S" that I've been slowly tinkering away with as the weather allows. She's ugly as sin right now, but she'll get there.
I've found a lot of helpful information on this forum while doing my due diligence and figured I should actually join up and have some conversations. First restoration project, first full engine overhaul, first lots of things... I've always been able to figure things out, and I've got all of the CSMs, factory assembly manuals, electrical diagrams, etc, but sometimes hearing from experience or "If I had to do it again" stories can solve the mystery.
The car is pretty much like it was when it left the factory, and aside from the layers of goop, sludge and dirt, appears in pretty good shape. Stock 350 / THM350, factory A/C, factory 2bbl.
It ran just fine before I tore the front-end apart and disassembled the engine. Stock everything, so a pretty good platform to take it where I want it, I think.
Along with the car, I received a 1968 455 that is rebuildable, and what I think is a 1967 TH400 a 1967 Buick "Super Turbine 400" TH400 with switch pitch. I'm torn between doing the 350 to 455 swap, or keeping this "S" all numbers-matching original and saving the 455 for another project if I can get my hands on another BOP A-body later on. Time will tell, or if I manage to blow up the 350- Hey, got a back up big block...
Goal is a solid, reliable street car with some attitude, nothing too crazy. (I tell myself that now...)
Looking forward to learning from you all and keeping another Olds on the road.
Cheers.
Old Nov 10, 2025 | 10:37 AM
Welcome to the hood. Great project car.
Old Nov 10, 2025 | 10:38 AM
69CSHC's Avatar
Cool car, nicely equipped, welcome aboard.
You cant go wrong either way.
Old Nov 10, 2025 | 11:32 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
Welcome. The 350 can easily make over 400 HP and TQ, roller cam, aluminum heads and better pistons with headers and duals. Also the stroker route for about 100 HP/TQ more. The 455 can make even more power. What heads and what year is the 455 supposed to be?
Old Nov 10, 2025 | 11:42 AM
Tri-Carb's Avatar
You state that you have an extra 68 455. The most horsepower and torque per dollar spent on a rebuild will come via the 455. I like the low-end torque developed by the 455 for street cars.
Old Nov 10, 2025 | 12:14 PM
ZSmith74's Avatar
Appreciate the welcome all. Thanks.
The 455 codes out to a 1968 out of Southgate, but had '71 G heads installed on it. I haven't taken it much further apart than that until I make some more room.
I don't disagree, and that motor keeps looking at me like the Green Goblin mask. I'm going to drop the 350 off at the machine shop within the next couple of days for cleaning and inspection, I should crack the big block open and take a look at things. I've got the time and resources to fix them both back up.
Old Nov 10, 2025 | 12:17 PM
Welcome
Old Nov 10, 2025 | 01:26 PM
CRUZN 66's Avatar
Olds Fever
Welcome to the group...
Old Nov 10, 2025 | 02:27 PM
Welcome, the 67 T400 may be a switch pitch and would require a special converter and activation switch and wiring.
Old Nov 10, 2025 | 02:47 PM
ZSmith74's Avatar
Good call, thanks for that! I cleaned the tag off, looks like a 67 Buick "Super Turbine" flavored th400 and has the wired solenoid for the switch pitch.
Learning new things on day one, right on.
Old Nov 11, 2025 | 12:05 AM
VI Cutty's Avatar
Being "just" a Cutlass S and not a W machine or other notable high value car, going with the 455 isn't going to be a big hit on the car's value. And if you want to play it safe, hang onto the 350. The 350 can be plenty of fun, but the 455 is even more funner if you don't mind the gas bill!
Old Nov 11, 2025 | 03:28 AM
Welcome, I would go for the 455 if it is a good builder- similar $'s cost to rebuild either so go for the big one!! Keep us informed!!
Old Nov 11, 2025 | 04:46 AM
JohnnyBs68S's Avatar
Cool project, welcome. Keep in mind that switching from a SBO to BBO will also require the front springs to be swapped to maintain ride height.
Old Nov 11, 2025 | 06:21 AM
Minibike Mark's Avatar
Good Morning, all.
Welcome!
I'd go with the 455, no replacement for displacement. Being a '68 you might get lucky and have a forged crankshaft.
Old Nov 11, 2025 | 06:49 AM
Rallye469's Avatar
I’m in the 455 camp.
More HP per $ = more fun
Cool car. My first olds was a ‘70 S post coupe.
Old Nov 11, 2025 | 07:33 AM
ZSmith74's Avatar
Originally Posted by Minibike Mark
Welcome!
Well you've had me thinking about it and convinced me. I was holding off due to the extra considerations I'd need for the swap, but I've already hit the point of no return so might as well...
"Well why not drop the tranny and have it rebuilt? Why not replace the front end suspension while the fenders are off? Why not bust rust and paint the front frame? Wait, I know a powder coat guy, Why not take the whole body off and restore the frame??"
Think I'll spend today getting it up on a stand and checking internals, then let the machine shop tell me if they think they can save it.
Thanks, folks. 😁
Old Nov 11, 2025 | 07:50 AM
Tri-Carb's Avatar
C heads are fairly common. If you see some locally, you may get a good deal. Increasing costs make shipping heads somewhat impractical.
Old Nov 11, 2025 | 08:06 AM
ZSmith74's Avatar
I've looked around for sure. Found a couple of pairs through the Bay, but yes, the shipping costs added onto asking price makes hitting any kind of "purchase button" a questionable moment.
Every local scrapyard around here doesn't have any Oldsmobile anything laying around anymore. It was kind of heartbreaking, BUT there is a place up near Kalispell that deals a lot in the classics. Going to get up there one weekend and see what I can load a trailer with.
Old Nov 11, 2025 | 08:14 AM
67OAI's Avatar
Old(s)GuysRule
Welcome aboard! Looks like a great project and a lot of fun!
Old Nov 11, 2025 | 09:53 AM
Tri-Carb's Avatar
Just over the line in Idaho and Canada:
L&L Classic Auto | Wendell, ID 83355
1969 Oldsmobile 442 | Muscle N' More
Old Nov 11, 2025 | 01:08 PM
therobski's Avatar
Just to give you a tickler, compared to what is available today for more HP, a picture of my 455 years ago I dropped in the 67.
Matt-NOTL
Dec 20, 2024 02:45 PM
7deuceCutty
Jul 5, 2022 01:14 PM
Cutlasskw
Nov 18, 2021 05:24 PM
Mingus
Jan 4, 2010 09:57 PM
Operation Deltapower
Aug 6, 2009 02:07 PM
