I joined this as a referral from one of the Buick forum guys. I have one of the 78 Buick Electra’s with the 403. Been in my family since early 90’s or so. The 403 is why I joined as there is limited info on the other sites. And to start off, No I don’t have one of the infamous SWM blocks 😂. Of course I posted pictures because what good is a thread without pictures….
for those that don’t know, the metal carrier olds oil pan gasket is really nice, part number is
Mahle: OS30534TC
Felpro: OS30471C Intake was a fun little side project, painted in cast color and hand painted the numbers.
You've got a beautiful car and you did a great job on detailing the engine.
You even have intake and exhaust manifolds without rust pits!
Gary
Thanks Gary, the intake has a little bit where EGR goes but have to look really close to see it, the exhaust manifolds came out great, I’m hoping they don’t turn once running but I baked them for awhile, wife wasn’t to happy to see car parts in the oven 😂 , I’m still trying to navigate the site, I definitely need to put a want Ad for a power steering pulley.
It’s coming along, sand blasting, painting and baking takes time though, never mind the mess please. When priming the oil pump… the valve cover leaked 🤦♂️. Glad I checked it verse in the car. This forum is great I can say that. If anyone is curious I’m using the duplicolor paint with ceramic for the brackets and pulleys, I’ve had great luck with it.
I hope it retains at 70% of its cleanliness, I put together a 77 corvette years ago and It had an oil pan leak… pulled the engine to clean and reseal since it aggravated me so much I despise oil leaks.
Nice car, and massive bonus with the olds 403! I’ve always loved that body style of the Buick/Olds/Chevys of those years. The car I learned how to drive in was a 77’ 2 door Caprice….they definitely floated over the road. Going into corners at high speed was a little scary though….😬….talk about body roll!!
I did a little more work the past few days while I await some parts, working on engine bay clean up has not been fun at all and getting the crossover on exhaust cleaned was not either there was 45+ years of oil and dirt that was like concrete getting off of it. Never mind the mess, it’s all toys/kid stuff awaiting to be donated or tossed. I have all new parts to rebuild the entire front suspension, contemplating doing that before I install engine just so I’m not fighting it as much. For those that have done the front suspension, is a coil spring compressor really necessary? Or will it just pop out when I drop the lower control arm with spindle.
It’s very much the same as olds so if anyone needs pointers, I can say the old bushings which may have been original were a huge pain to get out, new ones going in were a pain too, so much so I called moog customer service, they did inform me the lower ball joints are manufactured a bit larger, anywhere from .011-.019 larger. But I have one side done.
