403 olds
Old Mar 5, 2025 | 06:17 PM
Mikes78's Avatar
403 olds
Hi all,
I joined this as a referral from one of the Buick forum guys. I have one of the 78 Buick Electra’s with the 403. Been in my family since early 90’s or so. The 403 is why I joined as there is limited info on the other sites. And to start off, No I don’t have one of the infamous SWM blocks 😂. Of course I posted pictures because what good is a thread without pictures….
for those that don’t know, the metal carrier olds oil pan gasket is really nice, part number is
Mahle: OS30534TC
Felpro: OS30471C
Intake was a fun little side project, painted in cast color and hand painted the numbers. Intake was a fun little side project, painted in cast color and hand painted the numbers.
Old Mar 6, 2025 | 03:43 AM
Bfg's Avatar
Bfg
Nice job! Love those Electra’s, I’ve had a couple of them, they float like boats.
Old Mar 6, 2025 | 04:39 AM
Welcome to the site!!
Old Mar 6, 2025 | 07:25 AM
67OAI's Avatar
Old(s)GuysRule
Welcome aboard! We would like to see some pics of your Electra also! Nice job on detailing your 403!
Old Mar 6, 2025 | 08:17 AM
Mikes78's Avatar
The Buick pics on an olds forum 👀
Finding interior pieces has been fun.
Finding these pieces have been fun, but recently finally found them.
Old Mar 6, 2025 | 09:11 AM
VC455's Avatar
Barely Registered
Welcome, Mike.
You've got a beautiful car and you did a great job on detailing the engine.
You even have intake and exhaust manifolds without rust pits!
Gary
Old Mar 6, 2025 | 04:51 PM
Mikes78's Avatar
Originally Posted by VC455
Welcome, Mike.
Gary
Thanks Gary, the intake has a little bit where EGR goes but have to look really close to see it, the exhaust manifolds came out great, I’m hoping they don’t turn once running but I baked them for awhile, wife wasn’t to happy to see car parts in the oven 😂 , I’m still trying to navigate the site, I definitely need to put a want Ad for a power steering pulley.
Old Mar 7, 2025 | 09:04 AM
67OAI's Avatar
Old(s)GuysRule
Your Electra looks every bit as good as the 403! Very nice!
Old Mar 8, 2025 | 12:26 PM
Mikes78's Avatar
Small update
It’s coming along, sand blasting, painting and baking takes time though, never mind the mess please. When priming the oil pump… the valve cover leaked 🤦‍♂️. Glad I checked it verse in the car. This forum is great I can say that. If anyone is curious I’m using the duplicolor paint with ceramic for the brackets and pulleys, I’ve had great luck with it.
Old Mar 8, 2025 | 02:17 PM
jmcghee's Avatar
Beautiful car. Engine almost too pretty.LOL
Old Mar 8, 2025 | 02:44 PM
Mikes78's Avatar
Lol
I hope it retains at 70% of its cleanliness, I put together a 77 corvette years ago and It had an oil pan leak… pulled the engine to clean and reseal since it aggravated me so much I despise oil leaks.
Old Mar 10, 2025 | 04:15 AM
Great job!
Old Mar 10, 2025 | 03:15 PM
Saturn71's Avatar
Nice car, and massive bonus with the olds 403! I’ve always loved that body style of the Buick/Olds/Chevys of those years. The car I learned how to drive in was a 77’ 2 door Caprice….they definitely floated over the road. Going into corners at high speed was a little scary though….😬….talk about body roll!!
Old Mar 11, 2025 | 12:43 PM
Mikes78's Avatar
Almost go time
I did a little more work the past few days while I await some parts, working on engine bay clean up has not been fun at all and getting the crossover on exhaust cleaned was not either there was 45+ years of oil and dirt that was like concrete getting off of it. Never mind the mess, it’s all toys/kid stuff awaiting to be donated or tossed. I have all new parts to rebuild the entire front suspension, contemplating doing that before I install engine just so I’m not fighting it as much. For those that have done the front suspension, is a coil spring compressor really necessary? Or will it just pop out when I drop the lower control arm with spindle.
Old Mar 12, 2025 | 06:04 AM
VC455's Avatar
Barely Registered
Originally Posted by Mikes78
...will it just pop out when I drop the lower control arm with spindle.
I've done mine that way. I put a loose cable through and around the spring and control arm for safety.
Old Mar 12, 2025 | 07:38 AM
don71's Avatar
same but different
The old springs should pop out just fine, but be safe. You'll need a compressor when installing new springs.
Having the weight of the engine in the cradle will assist when installing new springs, but you don't have to.
Old Mar 12, 2025 | 08:31 AM
Mikes78's Avatar
I hadn’t planned to change them, not sure how they would go bad, but need to get control arms off to install new bushings and ball joints.
Old Mar 22, 2025 | 05:30 PM
Mikes78's Avatar
Updates to car
It’s very much the same as olds so if anyone needs pointers, I can say the old bushings which may have been original were a huge pain to get out, new ones going in were a pain too, so much so I called moog customer service, they did inform me the lower ball joints are manufactured a bit larger, anywhere from .011-.019 larger. But I have one side done.
GIDave
Jan 3, 2024 05:33 AM
durangomania
Jun 21, 2023 11:23 AM
Evilws666
Jul 26, 2022 11:33 AM
Skipper80
Aug 5, 2021 07:05 AM
77olds
Jun 25, 2021 05:36 AM
