Just sayin howdie
Old Aug 17, 2019 | 04:24 PM
MrEarl's Avatar
Just sayin howdie
Been lurking for awhile and wanted to introduce myself proper. Trying to learn all I can on the Olds 403. Got one in my '79 Buick Estate Wagon that we pull an Airstream Argosy with and looking to up the performance a bit. Lots of knowledge folks here I see, thanks for letting me join in.
Lamar in Athens Georgia
Old Aug 17, 2019 | 07:07 PM
Welcome to the site, nice travel combo.
Old Aug 17, 2019 | 07:45 PM
CRUZN 66's Avatar
Olds Fever
Welcome to the group... Looks like a nice way to travel...
Old Aug 17, 2019 | 08:50 PM
MrEarl's Avatar
Thanks guys. The wagon handles the tow well except for needing a bit more power. Sway bar added to the rear, heavier duty one to the front. New progressive coil springs and coil assist shocks on the rear and gas shocks on front. A set of LT load range 109 Uniroyal tires took the side to side squirrelly movement away and she hugs the road nicely in curves. Will be starting a thread soon to discuss some options on getting some more horsepower and torque
Old Aug 17, 2019 | 09:17 PM
Love the entire rig.
Old Aug 17, 2019 | 09:57 PM
Gotta love that setup.
As for more power, there are two things to consider.
First is a lower rear gear, which will make it feel as the engine has more power. Most vehicles with factory tow options have lower rear gears to provide better pulling power. Do you know what gear ratio your wagon has?
The second thing is the low compression ratio on the 403 engines. I think they're actually around 8:1 or maybe a bit less. If you want more power from the engine, it likely would likely require an increase in compression and a suitable camshaft to compliment the compression increase.
I'd look into gearing first as that has always been the best performance increase in my experience.
Old Aug 17, 2019 | 10:12 PM
MrEarl's Avatar
The wagon came with full tow package so has the 3.23 limited slip rear differential. Had the TH350 rebuilt and a RV shift kit added.
I’ll cover everything when I post the new thread in a day or so.
Old Aug 18, 2019 | 04:38 AM
Very nice, I love it! Is that still a carburated car? If so maybe you would want to switch to a 455? Lots of torque there! Ill be looking for your new thread- sounds interesting.
Old Aug 18, 2019 | 01:53 PM
rocketraider's Avatar
Oldsdruid
Oh lordy- we's bein' infilltrated by the Burick people!
Welcome aboard Lamar! We have some 54 Olds guys lurking here too.
I still kick myself for not getting those Doraville Assembly Plant letters from you.
Old Aug 18, 2019 | 04:34 PM
MrEarl's Avatar
and I'm still kickin myself for sellin them. Glad to see somebody I know here, look forward to hearing folks thoughts and opinions on the 403.
Old Aug 18, 2019 | 04:43 PM
My opinion is it is a good engine. Even in stock form it's rated 320 ft-lbs torque and with its 8:1 compression ratio can run on low octane fuel. Lotsa cubic inches in a small block package. What's not to like about that?
Old Aug 18, 2019 | 05:40 PM
MrEarl's Avatar
Oh, I definitely agree @Fun71 , what I probably should have said is look forward to hearing thoughts and opinions on making an already great engine even better. It has plenty of power for cruising around and actually tows the 4,500 lb Airstream OK except on some of the NE Georgia hills we've encountered. Re running on low octane, not sure about that, I've always used 93. Wouldn't mind plugging low octane into the formula I'll be working on for the upgraded engine build though.
Cutlasskyle
Suspension & Handling
Mar 15, 2018 09:54 AM
Army_Vet
Aug 2, 2017 01:45 PM
top down
Feb 10, 2016 08:52 PM
BlueCalais79
Mar 2, 2013 11:45 AM
steve's 1970
Jun 2, 2010 09:00 PM
