Replace a 1971 TH400 to Overdrive Transmission
Old Dec 25, 2017 | 06:44 AM
Red Dog's Avatar
Hello and thanks for letting me post. I am new at this so......here it goes. I owner a 1971 442 convertible, it has the original 455, TH 400 and 3.23 rear end. My mom ordered this 442 and I got it in 1977 with about 75K miles. I had the engine rebuilt in 1994 and it has about 20,000 miles on it since then, it runs well. The rear end has not been out of the car. My question is what to do with the transmission. The original TH 400 was re-built in 1994 and it shifts tight, except for a few leaks. I have started the 2nd major restoration and would like to have overdrive for improved highway drive ability.
Does anyone have a suggestion for an overdrive that requires the least amount of modifications. 344671M179031
Old Dec 25, 2017 | 07:12 AM
Welcome to the site, post some pics when you get a chance. My opinion on overdrive transmissions is if your not driving it all over the place mostly on the highway, money can be better spent on something else.
Old Dec 25, 2017 | 08:48 AM
anthonyP's Avatar
PM sent.
Old Dec 25, 2017 | 11:03 AM
Qwik71442's Avatar
Full-time Taxpayer
Gear Vendors Overdrive
Old Dec 25, 2017 | 02:27 PM
The 200-4R is the easiest swap but you will need to have one modified to live behind your 455. Expect to pay close to $3K for either that or a Gear Vendors. The 4L80E is the only OD trans strong enough in stock form, but it requires floorplan mods, a bellhousing adapter, and an expensive ECU.
Old Dec 25, 2017 | 02:34 PM
11971four4two's Avatar
MOTORHEAD
This is what I would opt for. Gear vendors are a few $$$ and require driveshaft mod. Nice way to fly and have basically 6 speed transmission.
Otherwise you could try a 3.08 or 2.73 rear gear ratio / and / or a taller rear tire I have been using 255/60/15 mickey thompsons on a couple of my cars.
Have Fun
Old Dec 25, 2017 | 02:41 PM
A lot of your car's value is in its originality. Give that serious consideration before you go do anything that can't be easily undone.
Old Dec 25, 2017 | 04:07 PM
OLDSter Ralph's Avatar
Simple words of wisdom worth considering.
Ralph
Old Dec 25, 2017 | 05:57 PM
Cutlass Fan's Avatar
What about a 700r4. Isn't it basically a 400 with overdrive? If so it should handle the torque. Not sure on mods needed ie trans mount and drive shaft.
Old Dec 25, 2017 | 06:16 PM
Charlie Jones's Avatar
Phantom Phixer
Gear vendors overdrive , approximately $2500 plus installation cost .
Average use of a "collector" car , maybe 1000 miles per year.
Approximate cost of gasoline $2.50 .
The best savings on fuel mileage with overdrive perhaps 5 MPG .
5 MPG / 1000 Mi. =50 gal. X 2.50 = $125 / year.
$2500 / $125 =20 years just to get your money back ! Before you save ANY money !
Save your money and buy gas!
Old Dec 26, 2017 | 06:40 AM
No. The 4L80E that I mentioned above is a TH400 with an extra OD gear set. Unfortunately, that extra gear set makes the 4L80E considerably longer than a TH400, which I why I noted that floorpan mods are required. The 700R4 is a new design that is not any stronger than a 200-4R in stock form. Either require expensive mods to live behind a 455. The 200-4R has a BOP bellhousing and is an easier trans to fit in an Olds for other reasons also.
Old Dec 26, 2017 | 06:41 AM
A reasonable consideration, but note that not everyone is only worried about gas costs. In my case, I want an OD trans so I can run 3.91 or 4.33 gears and not beat up the engine on the freeway.
Old Dec 26, 2017 | 06:44 AM
The GV may give you access to six different gear ratios, but two of them are worthless. Do you really need an extra gear between first and second or between second and third in a TH400? Do the math on the resulting ratios and effects on performance and you'll find that this sounds impressive but is useless in real life. The OD final drive is the only place that the GV is useful. Real six speed transmissions have a much wider ratio from first to sixth. The GV doesn't change that - first is still the same 2.48:1 of the TH400.
Old Dec 26, 2017 | 08:16 AM
You might consider rebuilding the 200-4R yourself if your mechanically handy. That would definitely keep your cost down.
Here's a well rated website that provides high-end transmissions and transmission rebuild parts.
http://www.monstertransmission.com/
Old Dec 27, 2017 | 07:06 AM
lansing's Avatar
Agree. Seems a shame no one makes just a simple final drive overdrive that would bolt up to a TH400. Maybe for a little less money than the GV unit. Weren't these available many years ago...or is my dementia kicking in again??
Old Dec 27, 2017 | 07:14 AM
I suspect you are thinking of the Hone overdrive unit, a predecessor to the GV. Both are simple planetary gear sets derived from the Volvo factory overdrive.
Old Dec 27, 2017 | 07:41 AM
lansing's Avatar
Thanks for the memory jog. Looks like they are making them again, at least for the 9" Ford rear end.
Check out this link for a little laugh.. http://hone-o-drive.com/shop/
Cheaper than GV?...aaaahhhhh no!!!
Old Dec 27, 2017 | 08:13 AM
Interesting. I was not aware that they were still (or again) in business. Those are purpose-designed to bolt to a Ford 9" to make it a two speed axle. The one I'm thinking of was a divorced unit that went behind the trans.
Old Dec 27, 2017 | 11:44 AM
MOTORHEAD
Agreed that what he / original poster is after final drive ratio...
Have you ridden in a car with G/V whose driver wants to shift 5 times and like it????
"Priceless"
Smiles per gallon
Old Dec 27, 2017 | 05:19 PM
zeeke's Avatar
Welcome aboard.
I know 69' 442 started saying it but this is a 71' 442 convertible, I'm assuming #'s matching, why mod this car? How much fuel will you save with a 200-4R vs. depreciation? However, if you do mod it make sure you hold the 400. If you really want to get fuel economy keep the secondaries closed.
Old Dec 30, 2017 | 11:21 AM
Steve Sabatini's Avatar
VC455
Hi, I have done 200R4 twice. in my, 71 455 VC and 70 350 vc. Both daily drivers. Engines stock, both transmissions fresh rebuilds with minor + parts (not really needed), all driven smartly, not raced. Only required mods include,
1) Driveshafts need need shortning,
2)trans mount needs relocation to preexisting secondary factory location,
3)TV cable,
4)OD lock up switch- I used a simple rocker.
I did it `cause I just wanted more relaxed cruise, even around town. Definitely worth it to me.
Only down side is, a bit crisper (bordering on harsh) 1,2,3 shifting.
Old Dec 30, 2017 | 11:26 AM
Originally Posted by zeeke
Welcome aboard.
Good point -- anybody who's using a car like this as a daily driver obviously has priorities other than fuel economy, anyway.
Old Dec 30, 2017 | 01:53 PM
Carshinebob's Avatar
My solution on the 71 442 convertible I owned many years ago was to change the rear end. Although My car had a non stock 3.55 in it when I got it. It was fun until the speed limit was raised to 70 from 55. I had a 2.73 laying around, so in it went. It made driving on the highway very nice. It changed the personality of the car but would still chirp the tires shifting to second. The surprise was that the quarter mile et was almost the same, but the trap speed and 60 ft. time changed a lot. probably a good example of how much low end torque can move a car even with a highway gear. So here's my recomondation. Finding a used 2.73 complete rear end wouldn't cost much and you could keep the original to maintain the value of your car. ~BOB
4speed455
39
Jun 8, 2017 05:22 PM
anthonyP
Jul 1, 2013 03:09 PM
White Spyder
20
Jan 16, 2013 03:13 PM
steve terry
Jan 13, 2010 07:14 AM
72RocketPower
May 26, 2007 07:23 PM
