I Got a new fuel senging unit but the Resistance when Full is different
Hello!! This is my first post here . Anyways I have a 1971 Cutlass S Holiday Hardtop and I just today put a new fuel sending unit it because I at least need an idea of where my gas is at. Is there a way to counter the extra 5 Ohms I gained with putting the new unit in? The original was 90Ohms and the new one is 95Ohms or is the difference on the gauge gonna be almost negligible because I know that 5 Ohms is fairly small. Thank you in advance
Here is the Unit I got: Fuel Sending Unit 692243
And ill have some pictures of the old Unit as well
If the gas gauge is linear with respect to resistance, then the extra 5 Ohms, which is probably a negligible difference, anyway, would cause the gauge to read slightly higher when full. If it was right on the F when full before, it'll be slightly past the F when full with the new gauge. If it was already slightly past F when full before, it will be a little further past F with the new gauge. Etc.
The gas gauge is just an Ohmmeter with zero resistance equal to E on the gauge and an open circuit (infinite resistance) equal to point on the gauge well past F, often the 3 o'clock position.
I wouldn't do anything other than put the new sending unit in and get on with life.
Thank you guys for the reply's i'm gonna just leave it alone
68RocketAction
December 18th, 2014 11:19 AM
help442onguam
March 20th, 2011 12:25 PM
