I Got a new fuel senging unit but the Resistance when Full is different
Old Nov 9, 2017 | 09:56 PM
Charlie Heaton's Avatar
Hello!! This is my first post here . Anyways I have a 1971 Cutlass S Holiday Hardtop and I just today put a new fuel sending unit it because I at least need an idea of where my gas is at. Is there a way to counter the extra 5 Ohms I gained with putting the new unit in? The original was 90Ohms and the new one is 95Ohms or is the difference on the gauge gonna be almost negligible because I know that 5 Ohms is fairly small. Thank you in advance
Here is the Unit I got: Fuel Sending Unit 692243
And ill have some pictures of the old Unit as well
Old Nov 10, 2017 | 02:06 AM
Ozzie's Avatar
Why not just give it a test. Hook it up with jumpers, put the float in the full position and see what the gauge shows. Then do the same for the empty position. You "might" be able to bend the float arm a bit, if needed, to accommodate the difference.
Old Nov 10, 2017 | 06:39 AM
jaunty75's Avatar
If the gas gauge is linear with respect to resistance, then the extra 5 Ohms, which is probably a negligible difference, anyway, would cause the gauge to read slightly higher when full. If it was right on the F when full before, it'll be slightly past the F when full with the new gauge. If it was already slightly past F when full before, it will be a little further past F with the new gauge. Etc.
The gas gauge is just an Ohmmeter with zero resistance equal to E on the gauge and an open circuit (infinite resistance) equal to point on the gauge well past F, often the 3 o'clock position.
I wouldn't do anything other than put the new sending unit in and get on with life.
Old Nov 10, 2017 | 12:28 PM
Alright man!!! Yeah I don't want to drop the tank again because I had to drop it twice to finish the job: First time to put it in then the second time was because I forgot to hookup the wires HAHA
Thank you guys for the reply's i'm gonna just leave it alone
Old Nov 10, 2017 | 07:08 PM
Yellowstatue's Avatar
If your car has a working odometer then you could fill it up every three or four hundred miles...
Old Dec 11, 2017 | 01:33 PM
Talking
LMAO I guess thats true.....But my transmission needs to engage the cable first before thatll work HAHAH
kuseetha
Sep 27, 2017 04:08 AM
bobsolds62
Aug 6, 2015 01:57 PM
RandyS
Sep 12, 2012 02:40 PM
help442onguam
Mar 20, 2011 12:25 PM
