53 oil pan removal
Old Jan 16, 2017 | 05:29 AM
Tropicalbill's Avatar
53 oil pan removal
Does the engine need to be lifted to remove oil pan on 53 303 cu"? Have both exhaust pipes disconnected from manifolds but not removed. Did not want to cut pipes if I still have to lift block. Crossover pipe is under pan only gained about 1 inch clearance with pipes loose.
Old Jan 16, 2017 | 05:53 AM
Tedd Thompson's Avatar
I don't know about a 53 but a 55 is almost impossible (probably impossible) to lift the motor up high enough to allow you to completely remove the pan. The rear main was replaced in my car by rotating the pan as far as it could towards the drivers side and work on the lower end that way.This is a very tight procedure and I could not do it myself, a friend who is half Hounidi got the job done but said never again. What are you trying to do under there?.... Tedd
Old Jan 16, 2017 | 06:04 AM
Rocketowner's Avatar
Smile '53 Olds oil pan Removal
I am not specifically sure about th '53,but on several years of Olds mid fifties it was necessary to Jack the engine up for the oil pan to be removed. It wasn't difficult because we had a mechanic that would start at 7:00A.M.,drop the pan, replace the rings ,polish in the valves,replace the valve lifters, put it back together, and drive it to pick his wife up from work at 4:00 P.M..If I was available,I would polish In the valves and clean the Pistons and the oil pan.
But if I was in school he could do it anyway. If I am not mistaken he jacked up the engine from the driver's side only. Larry
Old Jan 17, 2017 | 04:44 AM
Oil pan gasket was leaking bad and wanted to check/clean what I could with pan removed. Thanks
Old Jan 17, 2017 | 02:01 PM
Cool 53 303 cu" oil pan
Found detailed instructions in shop Manuel. #1) remove starter motor. #2) remove exhaust crossover pipe. #3 Drop steering relay rod by disconnecting idler arm support from frame. #4 remove pan.
Always use new gaskets and seals. Cement gaskets to pan and apply synthetic rubber seals front and rear. Coat exposed surfaces of the seals with graphite grease to prevent hang up on front engine cover and rear main bearings. Tighten evenly and torque 9-11 ft lbs.
Other than haveing to cut exhaust pipe after connection to newer pipe, it was not that hard. All the grease from steering was the worst part.
Thanks for all the suggestions. Hope this will help in future! Bill
Kaline
Apr 18, 2022 03:35 PM
Lawndog
Aug 21, 2011 10:14 PM
leadfoot067
Dec 3, 2010 06:11 PM
Fletch
May 18, 2010 12:40 PM
