oil pan removal
Old Dec 2, 2010 | 07:54 AM
leadfoot067's Avatar
oil pan removal
will it come out with the motor in the car? or do i need to pull the motor? 455 in a 71 cutlass with headers...
Old Dec 2, 2010 | 08:27 AM
InfoJunkie's Avatar
InfoJunkie
Yes it will. No you do not. Remove the distributor so it doesn't break on the firewall, undo the motor mounts and rad hoses,fan,shroud. Jack the engine up until it hits the firewall crawl under and struggle to get all the bolts outs. the struggle to get the pan out. It may be quicker to pull the engine and do it out.
Old Dec 2, 2010 | 02:15 PM
citcapp's Avatar
Pull the starter too
Old Dec 2, 2010 | 03:37 PM
Texas Jim's Avatar
Texas Jim
What kind of a crazy way is that to pull a pan? Let's leave the hammers in the box and if the engine needs to come out, then get on w/ it, and install something as you go back in w/ the engine that makes the pan removal more friendly f/ the next time.
Old Dec 2, 2010 | 03:48 PM
Redog's Avatar
If I had to do it, I'd probably take out the engine as well
Old Dec 3, 2010 | 07:29 AM
dc2x4drvr's Avatar
Been there,....pull the motor.
Old Dec 3, 2010 | 02:17 PM
X2. Yes, the CSM says you can do it without pulling the motor, but by the time you go through all the steps, you're a handful of bellhousing bolts and an hoist away from just pulling the whole motor. The first time the pan gasket slips out of place while you're trying to hold the pan up over your head, you'll really wish you had just pulled the motor.
Old Dec 3, 2010 | 06:11 PM
thanks guys..turns out i dont have to...changed the oil pressure gauge to auto meter sport comp and pressure is back to normal... gonna toss the cheap gauge...
Kaline
Apr 18, 2022 03:35 PM
Stevec
Mar 24, 2012 02:25 PM
Lawndog
Aug 21, 2011 10:14 PM
Fletch
May 18, 2010 12:40 PM
