will a 72 skylark front window frame fit an 72 cutlass? Need Help!!!!!!!
Ok, I need help! The front window frame on my 72 is so rusted that the window will not stay fitted, so I'm looking to cut one off another car. I know the 72 cutlass, skylark,etc are made on the same frame. My ? Will the lower Cowl and front window frame fit on my 72 cutlass. Thanks in advance!!!!
As long as you're replacing similar to similar, should work out fine. (Note: sedans, verts are NOT similar to 2 door coupes) I would stick with 70-72 donors though.
tmaleck
August 15th, 2021 08:17 AM
wblaster
April 8th, 2012 07:30 PM
oldspackrat
January 31st, 2012 10:59 AM
