Where is the fill mark on a 62 olds Starfire power steering reservoir
Old Sep 22, 2019 | 05:11 PM
Tcnugent's Avatar
I want to know where the top of the fill mark is on a 62 olds Starfire power steering pump
Old Sep 22, 2019 | 06:21 PM
Charlie Jones's Avatar
Phantom Phixer
The " full " mark is on the neck of the reservoir .
The level should be checked when the fluid is warm , and filled with Dexron III ATF .
Old Sep 22, 2019 | 06:32 PM
Tcnugent's Avatar
I’ve put NAPA power steering fluid in the reservoir, did I make a mistake?
Old Sep 22, 2019 | 06:38 PM
Phantom Phixer
If you just topped it off , you're OK .
A complete drain and fill should be ATF .
Old Sep 23, 2019 | 07:35 AM
Tedd Thompson's Avatar
I don't think power steering fluid would be a problem at all, they all are just a high grade type of hydraulic jack fluid. Most of the better parts of the ATF aren't used or needed for the function of the power steering parts in my opinion and that opinion it's worth what you paid for it.... Tedd
Old Sep 23, 2019 | 09:36 AM
Power steering fluid should work fine, like Tedd says, its just hyd fluid. I fill those to the base of the neck.
dinanm3atl
Nov 11, 2018 05:24 AM
Jetstar 88
Apr 17, 2012 04:25 PM
Joffroi
Nov 3, 2011 12:42 PM
1969cutlazz
May 8, 2011 03:04 AM
tpawlik
Apr 4, 2011 03:41 PM
