Weather seal problems
Hello all,,
I have a 1967 Olds 98 LS 4dr. I cant find the weather seal that runs up the (A) piller across roof line and down the (B) Piller,, and then up the (B) piller and across the roof to the (C) piller for the rear door seal,,
this car does not have frame around the door top,, the glass closes against the rubb seal on all 4 doors,, the center post does run to the roof line and seperates the doors,,
Please Help,
Thank You
Joexr793
Please Help,
Thank You
Joexr793
Hello all,,
Please Help,
Thank You
Joexr793
Please Help,
Thank You
Joexr793
This car is actually a "pillared hardtop" bodystyle 8669. It has no frames around door windows as a true four-door sedan would, but has a B post. GM was playing catchup to Lincoln when they introduced this elegant sedan body style, as Lincoln had already had it several years and had wild success with it.
Buick and Cadillac also used this bodystyle so you may be able to find it listed under those applications. You HAVE to specify it's a pillared hardtop since Fisher Body referred to all four-door sedans as "69".
