Is it a true 442
The VIN won't tell you because the 442 was just an option package in 1966, not its own series. That VIN decodes as a 1966 F-85 Deluxe 2-door hardtop with an L-6 engine built at Lansing, Michigan.
Could you get the 442 option on an L-6? I don't think so. This certainly sounds like it could be a car where someone has dropped in a V-8 and rebadged it as a 442.
The only way to know for sure if it is a 442 would be if you found a build sheet or broadcast card or if the care still had the dealer invoice. So what if it is just a Cutlass or F-85, you still have a good car.You could have had a 442 with a 6 but not that year.
Last edited by snowballs442; January 7th, 2011 at 05:33 AM. Reason: edit and spelling
So am I correct about the VIN? It indicates that the car should have an L-6, right? If the 442 package came only with a V-8, doesn't this indicate that the car is most definitely not an original 442, and that finding the build sheet isn't really needed to prove or disprove this.
In other words, the VIN alone can't prove that it IS a 442, but it can prove that it is NOT a 442. Correct? Or am I missing something?
In 1966 the third digit would tell you the engine type . If it said 4 you had a F - 85 V-8 6 would be a F-85 deluxe and 8 would be a Cutlass V-8 You would be correct Jaunty75. Still love the 66 Cutlass even if it is not a 442.
It wouldn't do to have a 250 cubic inch Six in there. What would that be? A 2.5-4-2? A 4-2.5-2? I'm not sure which of the 4's stood for the engine.
If it is a 442 Lansing built car,
it will have a V in column 5, on the trim tag.
http://www.oldsmobility.com/oldsmo/v....php?f=12&t=18
Jim
Jim
Jim
Jim
Since the 4-4-2 package was an option, you "could" start with a 6 cylinder and (back then) buy all the parts from GMPD to "convert" it to a 4-4-2, but it would be an "owner installed option" not a factory installation. You decide whether to call it a "clone" because an owner adding a radio or wheel cover option doesn't make the car a clone. Most people, however, don't install all the correct parts, just some of the appearance stuff. That is just plain incorrect on a technical level, and the "fraud" word often follows. . .
made in the usa
January 21st, 2011 06:48 AM
