Trim codes
Old Jan 11, 2020 | 02:28 PM
Doug Carner's Avatar
69 Ol' Blue
Trim codes
I was wondering if anyone could help me decipher my trim codes.
Old Jan 11, 2020 | 03:20 PM
69 = 1969 model year
3 = Oldsmobile division
44 = 442 model line
87 = Holiday coupe
OS = Oshawa, Canada assembly plant
529749 = Fisher Body sequence number
TR 930 = black bucket seat interior
512B10 PNT = Trophy Blue Poly (51) lower, black vinyl top (2B) upper, and black (?) striping color (10) <<< Note that I'm not sure on the striping color code
12D = Build fourth week of Dec, 1968
C60 = Air conditioning
D55 = center console
M20 = wide ratio four speed trans
Old Jan 13, 2020 | 09:35 AM
69 Ol' Blue
Thanks much for the response Joe! I am getting ready to send the block over to the machine shop to be dipped and see if the tolerances are good.
Old Jan 13, 2020 | 05:40 PM
Dan Mxc's Avatar
I could use a little help from you guys as well Thanks in advance
Old Jan 13, 2020 | 05:43 PM
Dan Mxc's Avatar
Better photo
Well, show us the whole tag. And if you are asking about those six digit numbers at the bottom of the tag, those are unique to Fremont and tie to the build sheet. They are not option or trim codes.
Old Jan 13, 2020 | 05:44 PM
Dan Mxc's Avatar
Cowl tag help
Better photo
Old Jan 13, 2020 | 05:46 PM
Dan Mxc's Avatar
Thank you for the fast response
Old Jan 13, 2020 | 05:52 PM
ST70 = Style 1970 model year
3 = Oldsmobile Division
44 = 442 model line
67 = convertible
BF = Fremont, CA assembly plant
00049 BDY = Fisher Body sequence number
TR 993 = blue bench seat with arm rest
25 A = Astro Blue Poly (25) with white (A) convertible top
10C = built third week of Oct, 1969
And as I said above, the two six digit numbers are Fremont-unique sequence numbers that are tied to the build sheet.
Old Jan 13, 2020 | 05:56 PM
Dan Mxc's Avatar
Thanks Joe that's what is what the car has now almost finished
Stan Shinker
Oct 7, 2019 07:01 AM
Sonicjagstang
Nov 19, 2016 08:21 PM
Hark442
Oct 25, 2016 10:14 AM
distributorguy
Jul 26, 2016 05:33 AM
L69
Oct 7, 2013 01:59 PM
