Tranny leak repair?
Old Aug 10, 2013 | 10:01 PM
D.B.'s Avatar
Question Tranny leak repair?
Folks,
Anyone ever use Blue Devil transmission leak sealant?
Old Aug 10, 2013 | 10:07 PM
svnt442's Avatar
If the seal is shrunken it will seal it. If where its leaking is split....nope. You're going to have to replace the seal. What is leaking? The input shaft seal?
Old Aug 11, 2013 | 08:49 AM
Originally Posted by D.B.
Folks,
I've used the Lucas trans additive as a stop-gap. Any of these "miracle in a can" additives are short-term solutions at best. They do NOT repair worn seals, as it isn't possible to add back rubber to the seal or fill a groove in a shaft. All they do is temporarily swell the rubber seals. They do this by softening them, which only serves to speed up the rate at which they wear out. Expect such a "repair" to last months, not years.
Old Aug 12, 2013 | 07:16 PM
D.B.'s Avatar
That's exactly where it's leaking. Plan on replacing, but just wanted to see if I could get something temporary without causing any damage. Thanks svnt 442!
Old Aug 12, 2013 | 07:20 PM
D.B.'s Avatar
Pretty much what I thought Joe. I am planning on replacing the seal. Just looking for something until I can get around to it. Thanks!
Old Aug 12, 2013 | 08:28 PM
If it's a minor leak, just leave it alone until you can fix it right.
Old Aug 14, 2013 | 06:20 PM
D.B.'s Avatar
That's probalby best oldcutlass.
76cutlass
Jul 7, 2013 07:10 PM
TopDown72
Nov 9, 2012 03:11 PM
Jakespeed63
Feb 20, 2011 05:56 AM
Jakespeed63
Feb 20, 2011 05:33 AM
miho35o
Ninety-Eight
May 7, 2009 06:50 AM
