Timing marks
Old Jun 16, 2016 | 03:04 PM
Fletchmo72's Avatar
Timing marks
What do you use to read your timing, since the timing mark on the harmonic balancer advances well past the factory timing gauge mounted on the motor (0-12 degrees).
Old Jun 16, 2016 | 03:29 PM
svnt442's Avatar
What distributor are you using?
If you are talking about checking total advance, then you either need a timing tape or a dial back timing light.
Old Jun 16, 2016 | 03:39 PM
Fletchmo72's Avatar
Okay thanks. Timing tape is what I need. My advance can is currently hooked up to ported vacuum on the carb. I'm changing that to direct manifold vac. And I need to see where my total advance is ending up at higher rpms.
Old Jun 16, 2016 | 03:41 PM
I prefer to use a dial back timing light. Then no tape required.
Old Jun 16, 2016 | 04:24 PM
Fletchmo72's Avatar
Don't even know what a back timing light is. How expensive are they? Any brand better than another? Thanks
Old Jun 16, 2016 | 04:40 PM
76olds's Avatar
Hookers under Hood
I bought the summit brand dial back timing light around Christmas 2015, I don't remember it being that expensive. I'm thinking $60.00..... but I can't be sure, my wife pays the bills and I'm only allowed to spend $60.00 at a time haha.
It is chrome and looks to be a decent product, I haven't put it to use yet so I can't help you on how to work it.
But ahhh, Oldcutlass will likely hook us up on how the thing works.
It did come with instructions so it should be self explanatory and work well.
I hope this helps
Eric
SUM-G1059 $65.97
Old Jun 16, 2016 | 04:44 PM
CRUZN 66's Avatar
Olds Fever
Check these out...
https://www.summitracing.com/parts/s...FcQjgQodCfELCw
http://www.google.com/shopping/produ...FVglgQodIZwA1Q
https://www.amazon.com/Ferret-Instru...k+timing+light
Old Jun 16, 2016 | 07:56 PM
Or you can look for a used one at yard sales, pawn shops, craigslist, ebay, etc...
Carshinebob
Sep 11, 2013 04:06 AM
bullet1
Sep 25, 2009 05:44 PM
Gbobby
Feb 4, 2009 06:31 AM
cisco88
Oct 17, 2008 07:12 PM
MIRADAMANia
Apr 22, 2008 01:00 AM
