Ticking issue
Old Feb 11, 2015 | 08:52 PM
Richard2010's Avatar
Ticking issue
Hay guys I'm new on here. I have a 1971 cutlass supreme coupe with a 350 rocket. Hooker headers, rpm performer intake, summit 650 cfm carb. Slight ticking noise coming from the driver side exhaust area. Not the exhaust though does anyone know if these stock heads have adjustable lifters ? Or would I have to replace or go with rockers ?? Thanks really appreciate the feed back !
Old Feb 12, 2015 | 12:25 AM
How do you know it's not the exhaust? Header/manifold leaks can sound a lot like a lifter issue.
If it is a valvetrain issue, the most likely culprit is a damaged or worn rocker arm fulcrum which should be apparent once you get the valve cover off. The valvetrain is essentially non-adjustable.
I'm still going with a header leak, though.
Oh, and welcome!
Old Feb 12, 2015 | 05:44 AM
Welcome to the site. Stock heads do not have adjustable rockers. I would get a mechanics stethoscope and double check the exhaust and valve cover area to see where your ticking originates.
Old Feb 12, 2015 | 09:59 AM
Thanks fellas !!!
You guys are great thank you. I actually had the long tube headers and intake installed just a few days ago cause I was told the ticking was from the exhaust manifolds being worped. However the noise is still there so I'm thinking it's under that valve cover. I'm gonna drop the oil today add a stabilizer change the oil and see if it helps any, if not then I will pull the valve covers n go from there. This site is awesome !!!
Old Feb 12, 2015 | 11:50 AM
Do the stethoscope thing and find out what you're dealing with before you start pouring a bunch of snake oil in with your regular oil.
Old Feb 12, 2015 | 01:35 PM
Yep the lifters were lose. I tighten them up put it back together and were good 👍. Gonna go ahead and get some rockers now. Thanks again fellas. Hay how do I change my profile pic of my car ? Thanks again
Finn5033
Jun 14, 2013 09:51 AM
69OldsCutlassS
Apr 30, 2009 02:49 PM
65az
Apr 25, 2009 05:43 PM
gibbo69olds
Oct 3, 2007 06:39 AM
matthew.burgess@yahoo.com
Aurora
Dec 9, 2006 02:49 PM
