Replacement Keys for 1977 Omega
Old October 24th, 2013 | 08:36 AM
  #41
Also note on the dealer brochure that the 305 is shown as "available after Oct 1, 1976". Apparently the VIN card was printed before that.
Old October 24th, 2013 | 09:12 AM
  #42
61reoldsman's Avatar
Hey Joe wouldn't have these brochures be printed long before the cars were even built?,so could there have been a snafu regarding what engine was actually available for the production line ?GM may have changed their mind at the last minute maybe?
Old October 24th, 2013 | 09:28 AM
  #43
Maybe yes, maybe no. Unfortunately, we don't know which was printed when. The dealer brochure clearly says that the 305 wasn't available at the start of production. The VIN card doesn't have a printing date on it. Ultimately, the O.P.'s VIN will be the deciding factor. This printing date issue is a continuing problem since obviously documents printed early in the model year won't cover mid-year changes.
Old October 24th, 2013 | 10:28 AM
  #44
The 1977 dealer brochure shows that the available V8s in the Omega line were the 305 2bbl and the 350 4bbl (Calif and high altitude only).
Yes, I understand that the 305 2bbl is not shown as being used by Olds on the VIN card, but that conflicts with the brochure.
Interesting.
So we have reasonably good sources that show that the only 2bbl V8 was the SBC 305, and that they were still painting them orange at the beginning of that model year, so we have a pretty good idea that if that car is all-original as the PO claimed, it has a 305 in it.
The final question would be: Is the 5th digit of the VIN a U?
Old October 28th, 2013 | 05:58 PM
  #45
hardgreg's Avatar
Joe / Eric,
Thanks for the additional information on the motor. I have been out of town, but I just checked the VIN and the fifth character in the VIN is U, so that is consistent with the brochure, and it sounds like it is most likely a 305. The car is still in Jacksoneville, and I am not, so once I trailer it down to Stuart, I will check the code on the head of the motor. Once again, thanks.
Old October 29th, 2013 | 06:56 PM
  #46
hardgreg's Avatar
joe_padavano, I am going to pull the lock cylinder and send you key codes when I get up to Jacksonville. From other threads it looks like the cylinder needs to be in the run position to be removed. Once the steerig wheel & lock plate are removed, how do you get the lock cylinder into the run position if you don't have any keys?
Old October 29th, 2013 | 07:04 PM
  #47
That's a common misconception, especially since it's what the manual says, but it's not true.
The column lock cylinder will come out in any position once you get the wheel, the lock plate, and the cover off, move the signal light switch out of the way, and depress the release tab.
Old October 29th, 2013 | 08:45 PM
  #48
What Eric said. Once you remove the steering wheel, lock plate, and turn signal switch, depress the tab and the lock cylinder comes out.
Old October 30th, 2013 | 03:12 AM
  #49
billmerbach's Avatar
major noob
Joe on my door lock I only had 3 digits 109 is that the code for the key
Old November 17th, 2013 | 07:22 AM
  #50
Ancient Iron's Avatar
Originally Posted by hardgreg
The car was given to me, I just need to get it out of the garage. It has 19,000 original miles on it, but it hasn't run in 19 years. Verified the motor is not siezed by turning by hand. SBC?
I was thinking a crate 350 might be a good replacement, it has a 260 V8 in it right now.
I hate to tell you the engine in your Omega is a small block Chevy
Old November 17th, 2013 | 07:31 AM
  #51
Been there. Sixth post.
Doesn't hurt to read the thread before commenting.
Old November 17th, 2013 | 11:47 AM
  #52
Thankyou to the forum Police
Old November 19th, 2013 | 07:51 PM
  #53
starfire's Avatar
Someone's got to keep this place from turning into total anarchy.
Garbled
March 24th, 2015 10:46 AM
meanmechanic01
August 2nd, 2012 10:51 AM
old blue
August 18th, 2009 02:22 PM
Snowdog
April 14th, 2009 03:51 PM
Vesuvian
September 14th, 2004 06:32 AM
Quick Reply: Replacement Keys for 1977 Omega
