rab62184 - Introduction
Old Oct 27, 2014 | 11:26 AM
rab62184's Avatar
Hello All,
rab62184 here. I just figured I would introduce myself. I have a 72 Cutlass (442 Clone) that currently has a 350 olds (original 2bbl) with #8 heads, stock pistons (low compression), th350 trans, and 10-bolt 8.5" open rear end. I have installed edelbrock 7111 intake, msd 6-al2 programmable ignition, flowtech headers, comp thumpr cam, FAST EZ-efi, a hydro-boost from an early 90s GMC. I think the rear gear is something like 2.73. not sure.
I am currently working on getting things rounded up to build a 455 big block olds. these are the parts I currently have : 455 olds block to be bored .030 over, 2323F .030 pistons, N crank (std dimensions), GA heads, bearings, gaskets, etc. It will be mated to a build 4l60E trans. i'm still thinking on changing rear gears though. I am looking to eventually put on procomp aluminum heads in the future as I don't have the dough for the edelbrocks.
So, yeah, that is where I stand.
Howdy.
Old Oct 27, 2014 | 07:49 PM
2blu442's Avatar
Welcome to the site! Please post pictures of your car when you have time. What part of the country/world are you located in?
John
Old Oct 28, 2014 | 06:04 AM
Welcome to the site, looks like a plan. Yes on the pics.
Old Nov 11, 2014 | 10:16 AM
rab62184's Avatar
Working on the pics! I'm in Houston, Texas...
Old Nov 11, 2014 | 12:14 PM
There are a few members in the Houston area.
Add yourself to the map and look up the other members in your area.
https://classicoldsmobile.com/forums...obile-map.html
Old Nov 12, 2014 | 10:16 PM
64Rocket's Avatar
In my opinion a gear change would give you your most improvement.
If you drive the freeway a lot, I suggest 3.42 ratio.
If you want more pop from the gas pedal 3.55 or 3.73 will be next, but will cut down on your freeway drive.
If you go with the over drive and the 3.73's that will be the way to go.
In my opinion.
Gene
74omega
Jun 25, 2008 05:35 AM
petritl
Jun 11, 2008 04:50 AM
gearheads78
Apr 3, 2008 01:51 PM
TheAcolyte
Jan 26, 2008 08:20 AM
blonzz
Sep 19, 2004 05:09 PM
