Quadrajet bowl leaking fix.
Old Apr 8, 2015 | 11:01 AM
garycc's Avatar
Smile Quadrajet bowl leaking fix.
I just found out that someone makes a well plug with O rings to fix a leaking quadrajet well plug. Tried everything else, ordered them and am waiting to see if they really work. Got them from Quadrajetparts.com for about $8.00 each.
Old Apr 8, 2015 | 11:29 AM
brown7373's Avatar
I have used O-ring plugs for the secondaries, but the primaries are more prone to leaking. Did you get a tap and allen head screws to thread in after you drill them out? Most agree that Marine-Tex Gray is the best epoxy to put on the threads on the plugs. You can get what you need from www.cliffshighperformance.com
Old Apr 8, 2015 | 01:10 PM
Has anyone ever really seen this problem on any 1968-later Qjet? It's pretty well documented on the 66-67 carbs with the pressed-in sheet metal plugs. It's extremely rare with the later spun-in aluminum plugs.
auto_editor
Jul 9, 2015 07:34 AM
BDK1973
Jun 9, 2012 03:20 AM
aliensatemybuick
Nov 12, 2009 03:11 PM
war eagle
May 8, 2009 03:53 PM
1965442
Sep 9, 2006 04:12 PM
