Please help 1972 cutlass convertible turn signal switch ?
Old Aug 19, 2017 | 04:42 PM
Beamin23's Avatar
I want to know do I need a turn signal switch with cornering lights or without cornering lights and it doesn't have a tilt steering wheel I change out the flasher the turn signal still not working including the turn signal Indicator Hazards work and all my lights though is the turn signal switch????
Old Aug 19, 2017 | 04:46 PM
Cornering lights were never offered on the 1972 Cutlass line. If a vendor is selling a turn signal switch for that car WITH cornering lights, run, don't walk. away.
What "flasher" did you change? If it's the one on the fuse panel, that is NOT the flasher for the turn signals, it is the flasher for the four way hazard lights. The turn signal flasher module is on a pigtail under the dash, to the left of the steering column. It is in the general area of the windshield wiper switch.
Old Aug 20, 2017 | 09:22 PM
Beamin23's Avatar
so what part number would I need if I don't have tilt steering column and the original shifter on the floor and I change the flasher under the dash still nothing and will the turn signal switch effect my turn signal indicator if the switch is bad ? Because indicator doesnt work either
Old Aug 21, 2017 | 06:11 AM
Before you get all wound up imagining what's wrong, check your hazard light operation. If they work, you just need to replace the defective flasher for signal lamps. Deal with this one step at a time instead of imagining what if situations.
Old Aug 23, 2017 | 09:09 AM
Beamin23's Avatar
i did still not working so what's next ? Turn signals not work or turn indicators
Old Aug 23, 2017 | 11:40 AM
Have you checked the fuse block to see if the fuse has blown?
Old Aug 23, 2017 | 01:08 PM
Beamin23's Avatar
yup no fuses are blown and all fuses in order use a tester and lights work in back
Old Aug 23, 2017 | 02:27 PM
Make sure you have 12v with the key on at the purple wire to the TS switch before you change it.
Old Aug 23, 2017 | 04:16 PM
m371961's Avatar
If you learn how to use a continuity meter and read the wiring diagram, you can know before purchase and teardown of the column. It is not that hard. Power goes into one wire and comes out 2 wires for the on positions of the switch. Someone here with a diagram can tell you what wires come from the switch leading to the lamps.
But certainly check for power going in first.
Old Aug 23, 2017 | 06:34 PM
It comes out in 6 wires. 3 for each side right and left.
Old Aug 23, 2017 | 06:42 PM
Do the parking lights work at the front and back when the light switch is pulled out to the first detent?
When you put the signal light on (right or left) do you get a solid green indicator on the dash?
Old Aug 23, 2017 | 08:00 PM
Beamin23's Avatar
any pics of what I'm looking for ?
Old Aug 23, 2017 | 08:01 PM
Beamin23's Avatar
any pics of what I need to pull out ?
Old Aug 23, 2017 | 09:22 PM
That would be the headlight switch.
Old Aug 24, 2017 | 04:12 AM
Your looking for 12v at the turn signal switch purple wire. There is only one purple wire hooked to the switch that comes from the signal stat. If you have voltage there then it is a problem with the switch.
Old Aug 24, 2017 | 06:43 AM
mrolds69's Avatar
It never hurts to put your location in your signature. Maybe somebody here lives near you that can help.
Old Aug 24, 2017 | 02:46 PM
Seriously???
If you don't know how to pull the light switch out to test the front/ rear running lights and side lights, how will you manage to test voltage from.the column? Maybe you should take this to a shop or have a friend who knows what we're saying do the tests.
San Fernando Olds
Apr 14, 2017 11:32 PM
costpenn
Jun 24, 2015 10:38 PM
ctrain22
Nov 6, 2009 05:53 PM
martine
Jan 22, 2009 01:13 PM
