Pertronix w/vintage tach
Old Jul 13, 2016 | 12:42 PM
Don Cannoli's Avatar
I installed a pertronix system in my 71 442 w/455, works great but my vintage tach doesnt work ..Help what to do?
Old Jul 13, 2016 | 01:15 PM
rcorrigan5's Avatar
Randy C.
I'm thinking that a fused line from the tach (factory tachs use a 2 amp fuse)to the negative side of the coil, plus a good ground for the tach, would do the trick. I've got pertronix in my '68 4-4-2 and that's how the factory tach is connected. My factory tach works great.
Randy C.
Old Jul 13, 2016 | 02:34 PM
What "vintage tach" do you have?
I thought all electrical tachs work off the signal on the coil and since the Pertronix is merely a transistor switch instead of a mechanical switch there shouldn't be any difference as far as the tach is concerned.
Old Jul 13, 2016 | 02:57 PM
Do you have it connected to the distributor side of the coil ( coil neg terminal)? Does it have power and ground?
RAMBOW
May 3, 2022 04:25 PM
StickW31
Jun 11, 2013 07:31 AM
MN71W30
Jun 8, 2011 12:13 PM
BerBer5985
Jun 21, 2009 01:26 AM
Chuck C
Apr 29, 2004 02:12 PM
