Our 1979 Firebird with Blown Olds 455
Old Jun 20, 2024 | 04:25 AM
DanV's Avatar
Hello,
Just introducing myself, my name is Dan and I live in QLD, Australia.
My wife and I own a 1979 Pontiac Firebird LHD with an Olds 455 / 8-71 roots blower that likes to drink E85.
I was doing research online for some aftermarket engine internals and stumbled across this site. Hoping to make contact with a few knowledgeable people and research/gather advice on appropriate parts.
My wife and I bracket race/drag race this car.
Hope to chat with you all soon.
Until then, Cheers!
Dan
Old Jun 20, 2024 | 04:29 AM
Welcome Dan, definitely a cool car! 😎
Old Jun 20, 2024 | 04:36 AM
SY2455's Avatar
70 442 W-30
Welcome to the site. Would you be willing to share more information about your build?
Old Jun 20, 2024 | 04:40 AM
DanV's Avatar
thank you!
Old Jun 20, 2024 | 04:47 AM
DanV's Avatar
Sure. We bought the car initially as a naturally aspirated drag car that had nitrous spray.
The we removed the nitrous and purchased a blower kit from DC Blowers.
8-71 stage 3 blower. Olds 455 with apparent good internals.
We recently did a head gasket and decided to strip the engine down for inspection, as it was the only thing we hadn't stripped and rebuilt since purchasing the car (recently rebuilt the TH350 trans with all Coan hard parts, new 3.5" chro moly tail shaft etc).
We found lunati pistons, stock GM rods and a stock N 455 crank.
We are looking for some advice RE pistons, rods and cam to suit a blown setup. Ideally want to drop compression, new pistons and rods, replace the cam with a more suitable item (JM5.6 hyd cam was found) and determine if the N crank will handle 8 to 10psi boost.
we have cast iron K heads also that appear to have had large valves fitted, decent dual springs, etc.
We also run dual holley 850 double pumpers modified for e85 (e85 metering blocks etc) and MSD powergrid ignition with ICE 10A module, ICE dizzy, coil and leads with MSD crank trigger.
Let me know if you would like to know anything I may have forgotten?
Old Jun 20, 2024 | 05:12 AM
Welcome to the site. What kind of time does it run?
Old Jun 20, 2024 | 05:27 AM
DanV's Avatar
We have had countless issues since buying the car, slowly coming to an end now though (we are running out of original pre purchase items as we have rebuilt everything after we do the engine) but it did run a low 11 with me backing off several times due to being a scaredy cat when the front wheels left the ground.
So I would say, with a proper transbrake launch, I expect a mid ish 10sec pass, with the 8psi pulley.
A correct camshaft to suit a blower would also assist here greatly also I believe.
Old Jun 20, 2024 | 06:12 AM
67OAI's Avatar
Old(s)GuysRule
Welcome aboard! Nice Firebird!
Old Jun 20, 2024 | 03:03 PM
dc2x4drvr's Avatar
Welcome, I think you’ll find info for your build at https://classicoldsmobile.com/forums...erformance-80/
Lots of good info, ask away.
Good luck!
Old Jun 20, 2024 | 03:45 PM
DanV's Avatar
Good luck!
Thank you!
Old Jun 20, 2024 | 06:30 PM
Welcome aboard! Nice car and good to hear you’re representing Oldsmobile “Down Under”.
Stay safe for sure, but so many would love to have your problem. 😀
Old Jun 20, 2024 | 11:04 PM
DanV's Avatar
thank you!
sean Buick 76
Mar 23, 2023 07:53 AM
rr69ho
Nov 13, 2021 10:03 AM
scottv442
Dec 24, 2016 08:51 PM
YeTI_north
Jun 13, 2009 10:53 AM
egknz
Jan 12, 2009 01:32 AM
