Olds 403
Old October 1st, 2009, 12:10 PM
kenny's Avatar
Olds 403
I am new to the forum an I looking to build a performance 400 H.P. Olds 403 at home. Any suggestions?
kenny is offline
Old October 1st, 2009, 12:22 PM
Find a good set of small block heads. I'm not sure what the casting numbers would be but I know 403 heads are a pretty poor choice for a performance motor. I think they have low compression.
Olds64 is offline
Old October 1st, 2009, 12:28 PM
kenny's Avatar
I love the Ferris Bueller quote. I understand the 72 350 heads are best part # 409147. I am looking for a set. Is anyone sure of the comp ratio with these heads and has anyone tested the results?
kenny is offline
Old October 1st, 2009, 12:35 PM
You might ask one of our members 2blu442 if he has any good SBO heads available. He has an amazing ability to find Oldsmobile parts.
Olds64 is offline
Old October 1st, 2009, 12:37 PM
Seasoned beater pilot.
J-(Chicago)'s Avatar
Kenny, do you happen to be in IL?
J-(Chicago) is offline
Old October 1st, 2009, 01:03 PM
11.52 @116
jims2000lt's Avatar
Early heads. 72 and older should help out. Probably need to go with an Edelbrock Performer RPM untake to make over 400 hp. I have a set of 1970 #6 heads here if interested. Crane springs new valves and 3 angle valve job. They were ported on by me about 10 years ago so nothing crazy for port work. PM me if you need any parts or info. Good luck.
jims2000lt is offline
Old October 1st, 2009, 03:30 PM
kenny's Avatar
I am a newbie, I will re-ask my question oin the proper forum.
kenny is offline
kenny's Avatar
Yes, I am from Illinois
kenny is offline
Old October 15th, 2009, 11:11 AM
1ATony's Avatar
Welcome to the site.
1ATony is offline
Old January 28th, 2010, 07:54 PM
dman0712's Avatar
i would use the kb pistons with a set of early big block heads. will put you in the compression ratio of about 10:1. cam with duration in the 230's and lift in mid 500's. Use really stiff valve springs. edelbrock rpm intake, headers. dont spin it over 5500.
dman0712 is offline
Old January 29th, 2010, 02:52 AM
Welcome
Welcome aboard
Glad you joined up with us.
Jamesbo is online now
Old January 29th, 2010, 04:45 AM
doc93's Avatar
Welcome.
If I remember 403 is a small block motor and big block heads won't work.
doc93 is offline
Old January 29th, 2010, 05:30 AM
70 cutlass s's Avatar
Originally Posted by doc93
Welcome.
Yes they will work. They are improvement over the stock 403 heads. Most people run a higher compression piston when they use bbo heads.
You have to remember sbo and bbo are similar design the bb is just taller deck. Most people are confused because Chevy are different and most people assume Olds are the same, but they are not.
You also have to use an Edelbrock intake with heads. On the same note using 350 heads are also an improvement over 403 heads.
70 cutlass s is offline
Old January 29th, 2010, 05:59 AM
Past Administrator
Oldsguy's Avatar
Welcome to CO.
Oldsguy is offline
Old January 29th, 2010, 09:58 AM
doc93's Avatar
My bad I read the other thread. And it was a good thing I did not know that when I had my 403.
doc93 is offline
88hurstolds
January 20th, 2020 11:39 AM
PetChemMan
August 10th, 2008 10:52 AM
esisson
December 19th, 2007 06:03 PM
Craftsman442
February 19th, 2007 07:43 PM
Quick Reply: Olds 403
