oldman8187
oldman8187
Guys I am newbie and have a question about a 1972 Cutlass can you use rtv between the bottom of timing cover and oil pan? Don't want to upset anyone but have done this on sb chevy before with great results.
ok thanks guys think i am going to have to pull front cover think eccentric that runs fuel pump might be bad. I have replaced pick-up in tank and new lines all the way to fuel pump. I am running and electric now and noise drive me crazy. Any thought one the eccentric being bad just wondered if tap might have broken off.
Welcome to the site oldman. I like to add that I've not experienced a worn eccentric and I don't think I've ever heard of that happening. I know stuff happens in the 40 years of who know who's been working on the car. Some one could have left it off.
Like Fun71 said, you should be able to identify the eccentric is there after removing the mechanical pump.
thanks for the input Fun71 and don71 I have removed the pump. engine is still car can use mirror and flash light and see eccentric. I have never seen it come off before either. Any ideas would be appreciated. A little this all started on a very hot day this passed summer, car cut off with me 4 times on way home would let it set a few minutes and it would start and run a couple miles. After i made it home there was no fuel in fuel filter. I took this as a bad fuel pump and replaced it with another one and same problem. I checked and replaced fuel lines fuel sending unit in tank and same problem still no fuel. It was in the middle of cruisin season and car shows so I just put an electric pump on it. Now I have started trying to find the problem. Today I removed the mechanical pump tested on work bench with rubber hose in a can of gas and worked the arm and it would shoot fuel half way across my shop. After that I hooked a vacuum pump to fuel line and pulled a good stream of fuel out of the tank. I also hooked a vac gauge to fuel pump and cranked engine and gauged would only move a few inches of vacuum.
