Oil pressure problems
Old Aug 3, 2010 | 01:41 PM
1970455sx's Avatar
I have a new rebuilt 70 455 and while priming the motor i have low oil pressure (about 10 psi) and no oil to two of the rockers. Does anyone have a idea what it could be?
Old Aug 3, 2010 | 02:05 PM
kaz442's Avatar
Are you spinning the drill fast enough?
Are you rotating the motor as you go?
Did they leave any oil galley plugs out?
Just a few thoughts
JKaz
Old Aug 3, 2010 | 04:32 PM
citcapp's Avatar
Are you rotating it counter clockwise? That's what you need to do. You need a high rpm drill 600 to 800 rpm
Old Aug 4, 2010 | 05:08 AM
Oldsguy's Avatar
Past Administrator
Welcome to CO and good luck with the new engine.
Old Aug 4, 2010 | 05:45 AM
MN71W30's Avatar
With my slow turning Milwaukee 1/2" drill, I've always had well over 60 psi while priming motors. Better hit the brakes on the project before starting it.
Old Aug 4, 2010 | 04:40 PM
1970455sx's Avatar
ok so i checked oil galley plugs and they are there, made sure I was rotating counter clockwise and got a faster drill and sitll have the same problem. Is it bad to run a high volume oil pump in a stock pan? could that be it, should i upgrade my oil system. Keep in mind the engine is mostly a stock rebuild.
Old Aug 4, 2010 | 04:57 PM
citcapp's Avatar
No, don't run the engine, you have a problem somewhere, bad oil pump or pickup sucking air, bearing clearance, or some other issue. should 50 lbs on a new build at least.
Old Aug 4, 2010 | 07:52 PM
kaz442's Avatar
What direction are you turning the drill?
Jkaz
Old Aug 4, 2010 | 08:09 PM
1970455sx's Avatar
counter clockwise
Old Aug 4, 2010 | 08:24 PM
64Rocket's Avatar
Are the two oil galley plugs in the front , behind the timing chain? also the oil plug in the back in front of the distributer gear?
Try a different oil gauge.
Gene
Old Aug 4, 2010 | 09:19 PM
kaz442's Avatar
Is it a mech or electric gauge? If electric does it have power and proper ground? Like said above try a different gauge. I have one that mounted to a long nipple that I thread into the oil pressure hole by the water pump just for priming.
Jkaz
Old Aug 5, 2010 | 11:03 AM
1970455sx's Avatar
i am gonna take everything apart and check again. i put a new guage on. By any chance will the oil filter housing have a spring? if so does that make a difference. i am going to check the oil pump also to see if it is bad or if the pick up is letting air in the system.
chasman414
Jun 25, 2020 07:05 AM
foreverolds
Dec 1, 2012 07:07 PM
RayJ
Tech Editor's Desk
Aug 30, 2012 06:08 AM
1970455sx
Oct 3, 2010 04:41 PM
airhead6969
Aug 10, 2006 11:00 AM
