Manual on removing sections of the steering column
Old Aug 4, 2010 | 07:32 AM
jfcutlass's Avatar
Hello...I am having problems with my ignition not working. I can turn the key and nothing happens. It seems that there is a problem in the section where the key cylinder is located. I can see the rod that runs to the ignition switch but there is another mechanism that is not connecting when I turn the key to start my car. Thank you so much. Jimmy
Old Aug 4, 2010 | 07:57 AM
The manual you need is a factory Chassis Service Manual for your year. You can find used originals on ebay.
Old Aug 5, 2010 | 04:55 AM
Oldsguy's Avatar
Past Administrator
Welcome to CO and good luck!
Old Aug 5, 2010 | 05:07 AM
Welcome
Welcome aboard
X 2 on the manual. It's a must have
Old Aug 5, 2010 | 10:43 AM
My442's Avatar
I would strongly suggest you follow Joe P.s advice and get a FSM.
The sterring column has a lot of parts, and there is a specific sequence to disassemble/assemble it.
Old Aug 5, 2010 | 04:10 PM
Run to Rund's Avatar
check ebay for a hard copy of the manual or join the Olds Perf. Club which is scanning the manuals and you can download them free:
http://wildaboutcarsonline.com/cgi-b...=9990286665833
starfire
Dec 9, 2021 08:21 PM
62 Olds
Mar 24, 2015 06:51 PM
317Cutty
Jun 18, 2014 10:53 AM
ros6872
Mar 28, 2014 09:48 AM
oddball
Mar 4, 2014 06:42 AM
