newbie 71 Cutlass S
Thanks guys I have a 71 cutlass S thinking about turning it into 442.
Doing a full restoration I'm in the process of stripping paint off driver side and took front clip off. I will start a thread here real soon. Cant wait too hear your guys opinions.
Lots of work ahead of you from the looks of that pic. You planning to do the body, then drop the frame or are you doing a frame on? I remember that green from when I was kid. Neighbor down the street had a 71 W30 car same color!
Goin too finish the body work and do then do my 1st coat of primer on it then remove it from the frame and redo the entire bottom can't wait for the rest of my body parts too come in
Trams question a update
Hey guys its been a while been busy with work but still dedicate a few hours a week to my car will put picks up soon
Do have a question I plan on taking my body off the frame here in a couple weeks so I can take the frame in to get sand blasted then I will bring it home and grind all the crappy welds down then send it back and get it powder coated
But my question is she had a 350 rocket in it and I plan on getting a 455 rocket for it can I use a th400 short tail in so I don't have to relocate the engine mounts and is that a good idea or not
Hard to answer
Figured out my color scheme!!!!😃 Was thinking red until I notice That there are too many red classic cars out there so I am going with a silver metalic main and for the hood stripes and pin stripe will be a gray metallic and black int and custom panels in it
455/400's were a standard combo for A body. Yes they were short tail for your year. Only difference I'm aware of is the TH400 uses different mounting holes than the TH350 in the existing trans cross brace. IIRC the thing you would have to change if you went long tail would be the driveshaft, not the engine or trans mounts.
usertroy
December 13th, 2012 08:19 PM
