Newbie 66 442 convertible
Old Oct 8, 2011 | 09:02 PM
Chuck_66's Avatar
Just purchased a 66 442 convertible the information that I found on this site helped me authenticate the car and hopefully the original engine. The car was produced on the 4th week in May and the heads were cast May 16th I could not see the date of the block I believe it should be just right of the distributor however I am not as flexible as I use to be.
Old Oct 8, 2011 | 10:04 PM
66400's Avatar
Likely to have 88 (Mar 29) as a casting date. You are right on the location of date code.
Henry
Old Oct 8, 2011 | 10:35 PM
Chuck_66's Avatar
I have a cast date on the passenger side head of 136 and 137 on the drivers the car was manufactured 05D. 136-88 = 48 that would imply that this engine was from a car manufactured 48 days after the fourth week in May?
Old Oct 9, 2011 | 07:30 AM
66400's Avatar
Head casting numbers of 136 and 137 would be May 16 and May 17. That precedes the build date of your car. What is the engine unit code stamped on the front surface of the passenger side head? Should start with the letter V.
Henry
Old Oct 9, 2011 | 11:35 AM
Oldsguy's Avatar
Past Administrator
Welcome to CO, glad the info helped you out.
Old Oct 10, 2011 | 12:36 AM
spiderjason's Avatar
Welcome!!!! Glad your here!!!
Old Oct 11, 2011 | 04:53 PM
Chuck_66's Avatar
Henry I have the S/N on the passengers head of V117873 thanks for the help.
Old Oct 12, 2011 | 06:59 AM
66400's Avatar
The engine unit number sounds good for your build date. I have a 66 442 that is a 5A build with V116648 engine unit number. Henry
Old Oct 12, 2011 | 09:45 PM
Chuck_66's Avatar
Thanks Henry you made my day.
halfmoontrail
Aug 31, 2013 09:05 PM
usertroy
Dec 13, 2012 08:19 PM
Scottem
May 29, 2012 11:24 AM
OldsCrazy
Jun 12, 2010 12:29 PM
marty
Site Help
Nov 30, 2009 06:08 PM
