New to Oldsmobile
Old Dec 16, 2024 | 02:34 PM
Raggamufflers 66Cut's Avatar
New to Oldsmobile
Hello , I am new today and can see from scrolling that you have some great and knowledgeable members.
I am pretty good with Fords and okay with Mopar but, needing help with my new purchase (trade really) a
66 Cutlass Convertable.
I was online looking at vin Identifiers but really didn,t get far as the vin on the Proteco plate is 12 digits and starts with a 6....
Its a Canadian car possibley made here?? but i want to be sure of that and other things .
If i drop the 6 it makes alittle more sense as the convertable code (67) then lines up.....
I have a few more questions but just wanted to say hello
Old Dec 16, 2024 | 02:38 PM
Welcome, post some pictures when you get a chance.
Old Dec 17, 2024 | 03:25 AM
Post photos of the VIN and cowl tags and we can help decode them. Canadian built cars DID get unique VIN tags in the mid-60s and a 1966 Canadian-built car will have a VIN that starts with "6". The VIN tag will also say "G.M. CANADA", so it should be pretty obvious if this is a Canadian-built car.
Old Dec 17, 2024 | 05:03 AM
Welcome
Old Dec 17, 2024 | 12:23 PM
Thanks Joe thats very helpful
Old Dec 17, 2024 | 12:37 PM
All Really helpfull stuff
This is the only pic that paints a bit of a picture , I bought the car pretty well in the dark so took many close ups of critical area's but not much post worthy
I will get a good pic when the rain stops ... which could be a few months ... i live in BC
Now to figure out motor
manual says its a 330 or a 400 in this year .
Its Gold and Wide ... but some of the parts service records quote 5,7 (i think its a good thing those weren't motor work invoices )
Could it be a 90 degree 350 motor?
Thanks again
Old Dec 17, 2024 | 03:17 PM
CRUZN 66's Avatar
Olds Fever
Welcome to the group... I am sure you will be pleased with the information available on this site...
Old Dec 17, 2024 | 06:33 PM
VI Cutty's Avatar
Welcome to the site! Sounds like you're on the coast...raining buckets here. Looking forward to more photos (and drier days!)
Old Dec 17, 2024 | 11:39 PM
The only factory-installed engine in a 1966 Cutlass was the 330. Base engine was the RPO L74 high compression 330 4bbl with 320 HP. The L73 low compression 330 4bbl with 310 HP was a no-cost option. The 400 only came with the 442 package.
Old Dec 18, 2024 | 06:00 AM
allyolds68's Avatar
You should be able to get all the option info for your car from VVS if it was built in/ or imported into, canada
https://www.vintagevehicleservices.com/
Old Dec 18, 2024 | 09:28 AM
ya is was like a pressure washer was flying over my house all night last night.
Car is tucked away in my crowded barn til March probably
Old Dec 18, 2024 | 09:31 AM
Thanks John , Nice list
Old Dec 18, 2024 | 09:48 AM
i just sent them an Email , Thank you
Old Dec 18, 2024 | 10:51 AM
I bought a rug from Jordan's Rugs about 20 years ago. It was pretty nice.
Welcome to CO.
Old Dec 18, 2024 | 11:31 AM
The old owner told me that the car sat in their showroom the first year of it's life
Old Dec 18, 2024 | 11:38 AM
Maybe someone has a pic of a 330 motor?
Mine looks like a 455 with a super wide manifold and narrow valve covers
Old Dec 18, 2024 | 05:16 PM
67OAI's Avatar
Old(s)GuysRule
Welcome aboard! There is a series of numbers cast into the engine block on what is commonly called the porch. This number series will enable you to determine the original factory size of the engine block. This is the area forward on top of the engine block and between the water pump and the intake manifold. It is where the oil fill tube and the oil pressure sending unit are located. In addition, you will find either a number or a letter cast into the cylinder head forward over number one cylinder on the driver's side and rearward over number eight cylinder on the passenger side. What we call the small block series has a number cast there and what we call the big block series has a letter cast there. That number or letter will determine the year or range of years that those cylinder heads were used by the factory. The only big difference between the two engine series is the deck height of the engine block. Valve covers are basically the same as the external dimensions of the cylinder heads is the same regardless of series. One other major difference is the lifter bank angle if a camshaft change is desired. Except for the 1966 and 1967 442 and Toronado motors, all 1966 and earlier blocks regardless of cubic inch displacement utilize a 45 degree lifter bank angle and all 1967 and later motors utilize the more common 39 degree lifter bank angle as do the afore mentioned 442 and Toronado motors.
File Type: pdf
Old Dec 19, 2024 | 08:31 AM
Super Helpful Jim
Thank You
Steve13
Sep 5, 2022 03:30 PM
haiopais
Aug 8, 2016 08:51 AM
mr.J
Mar 4, 2014 12:13 PM
vin442
Mar 9, 2012 08:08 PM
port
Sep 1, 2007 01:19 PM
